Liked 778 Times in 142 Posts
Gents, I have no experience with a 727 transmission.
I have a 1974 IH Scout II with that trans. If the scout sits for even a few days the converter drains back into the trans overfills it, then leaks on the floor. Is there a check ball or some other means in the valve body that is supposed to prevent this? It did not do this until recently. Kevin Panzino |
Liked 239 Times in 114 Posts
Where is it leaking from , the pan gasket or dipstick tube ? Best to fix those leaks , not much you are going to do to solve converter draindown .
Liked 138 Times in 51 Posts
Also check the case seal where the shift lever attaches to the valve body on the driver's side.
LOCOMOTION Racing |
Liked 273 Times in 109 Posts
Had 727,s in a couple bracket cars. If i filled them to the exact full mark on the stick, they would leak down to their happy spot. Probably about 1/4 quart then stop. So i finally quit filling them back to the full mark and they would stay right there.
Ok, I see. It probably always drained back to the trans, just now what has changed is that its leaking. I changed the pan gasket, no love. Hard to see where its coming from because it just runs along the pan rails and drips from the pan bolts.
Gonna take a close look at the dipstick tube seal, and the shifter linkage seal now. Thank you all for the input !!! Kp |
Liked 11 Times in 6 Posts
If the dipstick is the 1974 style there is an o-ring on the bottom where it inserts into the transmission unlike the push-in seals that they use today and I've had those o-rings get hard and leak. So the best fix for that is to get a new style seal and dipstick but unfortunately I don't know the part numbers for what you need but maybe someone else knows.
Liked 565 Times in 70 Posts
Also look at the neutral safety switch, on drivers side above pan rail. They get old and crack and leak down onto pan rail. It looks like its the pan gasket leaking.
Liked 2,516 Times in 701 Posts
Most common leak and most difficult to find is dipstick tube.
The new ones are a way better sealing arraignment. But a new O ring from the hardware store and making sure it is not bent up will usually save the day!
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 06-30-2020 at 04:40 AM. |
Liked 24 Times in 13 Posts
More than likely the culprit is the selector shaft seal.
Jeff Dudgeon '66 Coronet #10771 - bracket puke "the Flying Brick" |
Thanks guys. Gonna get it up on the lift and take a closer look.
