#11 |
Liked 358 Times in 83 Posts
I recently had the rear end of my car apart to change the ring and pinion, and when I was re-installing the driveshaft, I noticed that the output shaft of the McClay THM200 in the car seemed to be free to move around an awful lot. I immediately checked my spare McClay THM200, and the output shaft was exactly the same. With the driveshaft installed, the movement was all but gone. Never noticed that degree of movement with Powerglides or THM350s. Does the driveshaft slip yoke stabilize the output shaft that much, in a THM200?
#12 | |
Liked 7,938 Times in 1,519 Posts
#13 |
I've had units from both Turbo Action and Jack Sepanek and both companies will build you one that will last and get you into the winners circle .
Jack Matyas 1547 FS/C 2015 Camaro COPO # 62- 2012 Camaro Convertible COPO |
#14 | |
Liked 5,121 Times in 1,952 Posts
#15 |
All good options, so far ..
At least one missing... Think West...Way West ;-)
#16 |
Liked 455 Times in 147 Posts
X 2. Scott McClay. Worth every penny and very dependable.
Steve Teeter STK 620. |
#17 |
Liked 165 Times in 51 Posts
X3. Scott McClay.!
I use one in my AA/SA ZL1 427 it 60'S 1.28 at 3540 lbs! Scott is a great guy to deal with and knows how to build a 200 metric to last!
Glen DeMenge 1969 Camaro Stock Eliminator |
#18 |
I guess Tehachapi IS farther west than San Dimas , a little bit ;-)
I happen to know most all on these guys mentioned, so it's hard to recommend one over the other..Besides, that wasn't the o/p's question. There's a racer in Kansas that's a pretty good builder too..
#19 |
Liked 19 Times in 8 Posts
it's not, unless its a stocker or a generic 350 you get some weight savings a nickel on a Super Stock at least a dime on a Stocker But .005 is a lot we spend a lot of time and money looking for a tenth
Joe Schweigert 751 SS Last edited by Joe Schweigert; 06-04-2020 at 08:25 PM. |
#20 | |
Joe Schweigert 751 SS |
