Liked 357 Times in 119 Posts
Good Afternoon guys. It's time to start converting our 93 Z28 IHRA pure stock car over to be NHRA legal. Car is 90% ready it just needs a drivetrain. I already have a motor, next up is a tranny. Of course I had a good TH350 that I sold recently.....DOH! I also have a Metric 200 but it's bone stock. I have a few options for tranny builders but I wanted to pick your brains a lil. Other than the obvious, manual valve body, deep pan, etc. What do I need to make this thing live? It will get beat on as we bracket race... A LOT! LOL! Does it have the same input and or output shafts as the TH350? I have a good ATI converter for my old TH350 I'm hoping to reuse?? Also do I need a different yolk?? Mounting points?? Thanks in advance!
Liked 2,355 Times in 554 Posts
I highly recommend Turbo Action. I have had a few different brands that didn't do so well.
You will need another converter. The mounts, driveshaft, and shifter will work. The tail housing has metric threads for the mount, so you will need new bolts. |
Liked 239 Times in 114 Posts
If you get the rebuild through Scott McClay , he has an option to get you a 350/400 turbine shaft , and revised pump . That way you can use your current converter .
Liked 905 Times in 193 Posts
Get a J.W. Performance Ultra Bell. I cracked two cases before getting one. The case is the weak link on a TH200
https://racewithjw.com/product/ultra...-metric-to-gm/
Bob Don 128 SS |
If you don't go with the 350/400 changeover option, you still want to get a hardened stator support shaft insert.
Liked 2,343 Times in 465 Posts
Real simple Sepanek Racing Transmissions. I have 75 runs on his metric in a Big Block Chevy stocker. It's a 1970 402/375 hp making 635 hp. It's the fastest trany I've had in my car and it has lasted. BP
Liked 319 Times in 68 Posts
Sepanek all the way,best and fastest out there
Lee Valentine 1661 STK |
Thanks guys and keep em coming! I've been told the Metric 200 is about a tenth faster than a TH350. Hoping this is true??? I would hate to leave that on the table but I'm wrestling with the durability of the 350.
A good one will be fine behind an LT1. It will also be a little faster.
Liked 799 Times in 236 Posts
Billy Lynn does also a great Metric 200. If you've got a TH350/400 convertor, you can have a input for those installed along with the appropriate pump mods. The governor driven auto 1-2 makes them very consistent. The JW bell housings are a worthwhile addition or you can fabricate a brace for the stock case. Also, the Lokar flexible dipstick makes life a lot easier. The marks on the Lokar unit aren't correct so you need to remark it relative to the oil pan flange on the case. Retapping the oil pan holes to 1/4X20 from the metric size is another thing to do to simplify things. If you elect to have a roller rear bearing installed in place of the bronze one, the drive shaft yoke will likely need to be turned down about .020 for proper fit.
For what it's worth. -Al Billy Lynn (501) 278-0651
"That'll never work....." |
