If you're using a SOLID lifter then the Techs should use the lifter that's in the engine. I've been bit by lifter height before when going through a teardown in the days before the Techs had an adjustable lifter.
Liked 1,983 Times in 597 Posts
I don't race in Stock but I do race a super stock car. I don't see why they don't allow the roller lifters in all stock engines. Many of the newer cars come from the factory with roller lifters. Might even things out a bit and help some of the old iron keep up with the newer stuff. Stock is pretty much like the old time super stock now.
Mike Pearson 2485 SS |
Liked 8,217 Times in 1,537 Posts
Liked 172 Times in 81 Posts
There are a lot of older combos out there where aftermarket roller cams / lifters are not available and wouldn't be able to take advantage of the benefits, so much for a level playing field.
Jim Mantle V/SA 6632 |
Hoo boy, Jim don't get me going.
#6 | |
Liked 783 Times in 195 Posts
Billy, it will take a whole lot more than roller lifters to help that junk you race. Just sayin'.
But Dwight, it's good junk!
Liked 165 Times in 59 Posts
I agree with mike ,keep it the way it is ,,,ss has the unlimited valve train specs ,,,yeah stock isnt stock but there are limitations to the class,if you have performance common sense and some sweat equity, you can achieve a bunch and have satisfaction on your accomplishments
Liked 320 Times in 102 Posts
Is it time to start tilting at windmills, again????????????/
Just askin'
