Liked 706 Times in 283 Posts
The way I have read the rules there are 3 forms or types of ways to install weight or ballast.
1- 2 weight boxes that weigh 100lbs each 2- 100 lbs of bolted to frame removable weight 3- Bolting and welding permanent weight Total of 500 lbs max. Asking as I need to add like another whole car of weight on Olds wagon. It is way to light for T or U/sa |
#2 | |
Liked 312 Times in 175 Posts
#3 | |
200lb bolted and welded 100 lb. Bolted 1 weight box with contents 100lb Does this work? |
Liked 280 Times in 139 Posts
The way I understand it is you can have one weight box with a max weight of 100 lbs,or two with a max weight of 50 lbs.each.Or you can have 100 lbs bolt in weight but no weight box.Any other weight that's needed up to 500 lbs,has to be welded.Maybe I've been doing it wrong all these years lol......gsa612
Liked 5,140 Times in 1,962 Posts
Still not there.
Assuming you need 300# ...100 to make T, 200 and change more to make U. So you want 100 # total including box. The heaviest spare that fits the car, it's mounting hardware, plus a factory jack. That weight is free. Doesn't count as anything towards the ballast rule. Now make up the difference with a piece of plate or railroad track, two 1/2" bolts through frame , per 100#. Now, when you want to go back to T/SA, take the complete weight box out, the spare and jack , plus some gas ,and you're there. BTW , I had 650 # in my Omega for O/SA, and nobody weighed anything. ;-)
#6 | |
Liked 240 Times in 112 Posts
Question on the 1/2" bolts thru the frame. What about a uni-body car?
Dave Noll, EF/S ,?/SA 6526 |
Dave, You can go through the sheet metal sub-frame, with some big flat washers or plate underneath.
That's nothing. My turbo Mustang had that much.
