Still not there.
Assuming you need 300# ...100 to make T, 200 and change more to make U. So you want 100 # total including box. The heaviest spare that fits the car, it's mounting hardware, plus a factory jack. That weight is free. Doesn't count as anything towards the ballast rule. Now make up the difference with a piece of plate or railroad track, two 1/2" bolts through frame , per 100#. Now, when you want to go back to T/SA, take the complete weight box out, the spare and jack , plus some gas ,and you're there. BTW , I had 650 # in my Omega for O/SA, and nobody weighed anything. ;-)
#2 | |
Liked 708 Times in 285 Posts
Liked 240 Times in 112 Posts
Question on the 1/2" bolts thru the frame. What about a uni-body car?
Dave Noll, EF/S ,?/SA 6526 |
Dave, You can go through the sheet metal sub-frame, with some big flat washers or plate underneath.
That's nothing. My turbo Mustang had that much.
HHMMM...
I realize that I know almost nothing... but but SOMEBODY has to ask this ! ! ! Why the dedication to making the car so much heavier ? ? ? How I see it A station wagon, by it's very design, already has a weight transfer advantage. Obviously, the lighter car is faster. The lighter car is easier on chassis parts... and even the body, if the intended added weight isn't in the form of structural improvement. Why not go up a class ? Besides, faster is funner ! just say'n
Aubrey N Bruneau 6409 C/S 62 BelAir sport coupe, 409 HP 409 |
#8 | |
First of all , a lot of racers don't pay any attention to the lower Stock classes. They do indeed ,think faster is funner ( and much more expensive..MY) Also ,they're convinced they can't win much , without being a chaser, running in the 10's. However, the fact remains, you have to hit the tree and run close, if you ever want to win anything, without relying on luck. Okay..On to the answer. T/SA index ,14.40 @19 lbs. per. U/SA index , 14.85 @ 20 per. Difference , .45 seconds. At 204 hp, to go from 19 to 20 lbs. per, that is the amount of weight you would add. You can probably extrapolate it from there.
To run T I need to be 4103 lb.
To run U I need to be 4310 lb Currently the car with driver and 3 gallons of gas is 3880 lb. Yes a wagon will have good weight transfer but I need to meet minimum weight to fit in class. With the extra weight in the rear it will really transfer. |
Ah yes, I didn't realize that about T / U .
Makes sense now.
