Old 11-10-2018, 12:52 AM   #4
Eman
Liked 133 Times in 76 Posts
Default Re: 2 step pressure switch question
I used a standard non adjustable switch from local auto parts, I know Jegs sells a similar one. Mine is 1/8" pipe and threads right into my line lock solenoid, it has multiple ports. I also have a small LED on the dash to indicate the 2 step is activated. I use a transbrake button style switch on my steering wheel to activate the circuit. When I stage my thumb is on the button and when I step on the brake the LED comes on and the 2 step is activated. Release the brake pedal and the 2 step is off. I take my thumb off of the steering wheel button after launch and I can scrub the brake at throttle and not stutter.
