Old 09-12-2018, 05:03 PM   #1
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Default Re: Quick release steering wheel
While there are direct bolt on hubs available for various Ford and GM columns ,I don't know of any that fit the earlier Mopar splines.
I would replace the stock shaft with a .065"x .750" chromemoly shaft and replace the stock bearings in the tube with a nylon bushing.
By using the 3/4" shaft you can choose from dozens of quick release hubs.
Borgeson has couplers for just about any steering box or you could machine the trunion shaft to fit the 3/4" tube.
Tom; Can you send me in the right direction for these direct bolt on hubs available for various Ford and GM columns? I have a '70 Olds Cutlass, and would like to keep the stock column/steering wheel with a quick release.. Thanks for any info...
Bob
Old 09-12-2018, 05:38 PM   #2
Nmbr1GMfan
Bob
Grant "has" them for GM vehicles that are NHRA legal. They claim not to have any to ship till October.
Todd Greene
Old 09-13-2018, 01:19 PM   #3
John Brown
John Brown's Avatar
Liked 13 Times in 3 Posts
Most, if not all Mopar steering gear equipment of that era were made at Saginaw steering (GM plant) so any GM kit will work.
John Brown 3451 SS
John Brown is offline   Reply With Quote
Old 09-13-2018, 04:19 PM   #4
rallye bob
rallye bob's Avatar
Do these "direct bolt on" hubs for various Ford and GM columns, move the wheel closer to the driver?
Old 09-19-2018, 11:18 AM   #5
app01
On my 70 Mustang I put a bolt on one from Cobra automotive. The steering wheel is about 1/2" closer to the column, but that is in part to also using an aftermarket wheel.
+1 on adding a weld bead, and I did one that can later be ground off to put the OEM wheel back on if wanted.
Tony
70 Mach 1 Mustang w/ SBF Boss Block 460 Stroker
app01 is offline   Reply With Quote
