Old 12-10-2017, 06:25 PM   #15
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
Default Re: E shift ?
Your stick car needs shifted with the front end way up in the air?
I raced stick cars a lot longer than I have an automatic, but only one ever needed shifted in the air, but not high enough I could not see the track, to I could tell where I was in my lane. The car I have now does. Bump steer has been corrected, but if the front wheels are not straight when they touch down...
If you run a stick car, it really does not apply to you, does it?
What car & class are you actually running right now?
seeing as you seem to be looking for an argument, I guess i'll oblige.
WHAT THE HELL ARE YOU TURNING THE STEERING WHEEL UP IN THE AIR FOR????
and for the record, what does THAT have to do with shifting a stick OR auto?
and as far as what class i'm running is irrelevant to my question but at the moment, i'm not running ANY class, you got a problem with that?
