Old 09-15-2017, 03:59 PM   #22
Bruce Noland
Liked 444 Times in 145 Posts
Default Re: Crate Motor Class
Originally Posted by PozQB14 View Post
10 years ago the 350/330 was using a vortec head that you can literally find on Craigslist for a couple hundred bucks. 10 year from today, the 350/330 will be using the same head. As a current CM racer, I can promise I'll never ask IHRA or "maybe" nhra to approve a bogus aluminum cylinder head even though there is the 350/385 that runs one but the specs of the engine are much different. Only aftermarket stuff you really need is maybe a block which is very unnecessary (mine is a stock 350 .060 4 bolt main, nothing special) Actually bought it off Craigslist for $250 then had it decked and honed. Got lucky it was a decent piece. most use a victor jr and a holley 750. Some guys might get crazy with the trick ring package, not me. Way to expensive and not worth it. These are not fancy or special engines. At farmington this past wknd I literally rolled off the trailer, put gas in and went to staging cause I was in a hurry (barely had time to check tire pressure which was a little low) to make a pass and still went low 6.60's.
It's a low maintenance engine that can go 100's of runs before a freshen up, as is the 350/385 with aluminum heads with a larger cam ect...
It's very simple, guys that have 25-30k in there rockets can't handle getting put on the trailer by a low budget CM. It's a pride thing. But really, when the light turns green, are you not going to go because the other guy has a crate motor?
Funny thing is, the best sportsman racer in the history of drag racing has no problem mixing it up with IHRA guys as well as numerous other guys that were even at Indy this year in stock, some who were even class winners. Simply put, if you're a racer then strap up and race regardless of your opoonents combo. If you build a car for the prestige, go to Barret Jackson.
Thanks for all of your lovely advice. But let me splain something to you. Nhra Stock racers built and or purchase their cars to run in the NHRA system. It's not our problem that you wish to run a low budget crate motor car. There are tons of races for you to attend. Enjoy your car where you are wanted. And for the record this discussion has been going on for decades and nothing has happened. And if nhra ever allows crate motor cars into Stock they won't be the low budget variety. They will be the new OEM motors and not what you're thinking at all. Get used to it!
Bruce Noland 1788 STK
