Your location may help in directing you to a good shop.
I believe Holley has a list of approved dealers and installers. |
Liked 2,353 Times in 554 Posts
I would get with Holley. They have some sharp people. Also, if you get the opportunity, their classes are worth attending.
Liked 800 Times in 337 Posts
I would recommend Scott Clark.
He can give you immediate help. I would also recommend you attend one of his classes. They are a good value. He can work with most anything, Holley, FuelTech, Megasquirt and others. He has tuned everything from Bonneville Cars to NHRA ProStock and more. He is a straight shooter and a good guy. scott@realtuners.com https://realtuners.com/ https://www.facebook.com/RealTuners-...1791515720605/ Good Luck! Bill |
Liked 275 Times in 76 Posts
Jeff,
There are a couple of guys on the Holley forum that will help you and also review your system. One of the guys has his own shop and knows his stuff and also races. Have you tuned it on a dyno? Also if you are not running an NTK O2 sensor that could be a source of poor performance. My standard O2 only lasted thru 2 dyno sessions and roughly 15 gallons of C16 when the motor fell on its face while testing. I already had an NTK and the motor came back to life. There is a lot to be had with the timing and AFR tables, if your timing sync is not correct or stable thru the RPM range that may be another thing to look at. Sean
Might want to dyno it with a carb to verify it is an EFI tuning issue, not the engine.
Ed Wright 4156 SS/JA |
Liked 274 Times in 105 Posts
Ed,
we are borrowing a set of BLP carbs to test with. That will be the telling. |
Thanks men. I have messages into Holley and Scott.
