Old 06-06-2017, 04:22 PM   #1
GTX JOHN
Liked 2,483 Times in 697 Posts
Default Re: Hardblock?
.130 at Std. Bore is rather thin.
Might be worth checking a few more blocks.
If that is on thrust side I personally would not like to us that block.
Suggest filling it to within a inch or 1 1/2 to top of water passage if
I did use it.
John Irving
741 Stock
741 Super Stock
Old 06-07-2017, 10:13 AM   #2
randy wilson
Liked 22 Times in 22 Posts
Do what you want, but I wouldn't hard block anything. Did a 0.060 over 283, and a 0.030 327, and if you could watch the shaking of the stones when rehoning after teardown, versus ones being honed without any hardblock, you'd know what I mean. They never, ever, stayed round. And everything was done with two torqueplates, mains, and pump installed. I have never used it since.
don,t have one
Old 06-07-2017, 11:04 AM   #3
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
If you had the choice , wouldn't it be better to start with a good block , like a Bowtie or Dart ? A filled block has other problems like bores going out of round , or cooling problems when racing . What does a filled block weigh , compared to a Bowtie block . Plus after you where it out for bore size , it can be sold to someone that can use a bigger bore size . In the long run it might not really cost more to run a good block .
Old 06-07-2017, 11:05 AM   #4
James L Miller
Liked 25 Times in 16 Posts
I did use it.
John, I've attached the sonic check of the three 273 blocks I had sonic checked in January. The "orange" block checked worse than the "greasy" and "rusty" blocks. None of them were all they great. I think I will build a 2bbl engine with one of them, save the best for a 4bbl engine after I get my feet wet (hopefully not literally) with the 2bbl engine on building Stocker engines.
ID:	40134   Click image for larger version
ID:	40135   Click image for larger version
Mopar 2 Ya!
Old 06-07-2017, 02:50 PM   #5
richie 2
Liked 205 Times in 93 Posts
Im trying to build a "seat time" unit togeather. bowtie or dart is not in the budget. using pistons from the 80's w/low runs. what did everyone do before filler came along? thankyou everyone for your input, keep them coming...
Old 06-07-2017, 03:09 PM   #6
Mike Pearson
Mike Pearson's Avatar
Liked 1,923 Times in 578 Posts
Originally Posted by richie 2 View Post
Im trying to build a "seat time" unit togeather. bowtie or dart is not in the budget. using pistons from the 80's w/low runs. what dis everyone do befor filler came along? thankyou everyone for your input, keep them coming...
Years ago a stocker was only allowed .035 over. The stock blocks were pretty good at that size. Now with the more overbore the need for block fill or the better aftermarket blocks is needed. I personally have not had good luck filling the stock blocks and running at .060 . several have cracked the cylinders. You will be much better off to save a few bucks and get the aftermarket block. They are much stronger in the cylinder walls and deck. The bores will stay round and straight. The lifter bores are also very accurate on the aftermarket blocks. Believe me it will be money well spent. I wont even fool around with stock blocks any more and its real hard to find the older 4 bolt main blocks that are the best.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 06-07-2017, 07:44 PM   #7
MR DERBY CITY
Liked 7,937 Times in 1,518 Posts
Very good advice Mike....there is no saving $$ in drag racing ...purchase a bow tie block, it will last you forever.....do it right the first time, you will be glad you did.....
Old 06-07-2017, 08:40 PM   #8
Hacksaw
Liked 310 Times in 174 Posts
Didn't know there is a bow tie block that matches a 273 Mopar.! Oh! The curse of trying to make 50 something old run with modern stuff.
Old 06-07-2017, 09:45 PM   #9
David Lee
Liked 346 Times in 126 Posts
I guess the real cure without buying a 3K block and getting thick walls, would be to sleeve a 318 to 273 bore size
Old 06-07-2017, 03:50 PM   #10
65signet
Liked 44 Times in 21 Posts
It seems that all the 273 blocks are a little thin, the 67-68 i have found are the worst, i had to fill my block.
Steven Barnes
Stock 704 N/SA
65signet is offline   Reply With Quote
