Old 04-26-2017, 03:44 PM   #1
Jamie4127
Default Re: Help with inconsistency
Jamie, A 4900 converter that all of a sudden goes to 6K, isn't going to last more than two runs, if that long.
I made 5 runs, maybe 6 that day when it acted up. Right after that we had it checked along with the trans and was told it was okay. Also that same week I changed my fuel sending unit and had my injectors checked thinking it was a fuel issue.
Now same converter it goes to around 5500 off the line. Its hard to say because it happens very fast and I have to shift right away or it hits the rev limiter. There has to be 10-12 runs on it right now.
Jamie4127 is offline   Reply With Quote
Old 05-02-2017, 12:00 PM   #2
Coach
Coach's Avatar
Liked 2 Times in 2 Posts
Did you get a chance to run this past weekend? RPR this weekend?
Coach is offline   Reply With Quote
Old 05-02-2017, 12:23 PM   #3
Jamie4127
Yes sir we actually went to hmp friday night. 1st pass it still ran slow but it didn't hit the rev limiter right away like before. Also the converter I tried is about 600rpm looser then mine. 2nd pass same thing but it picked a tenth in the 1/8th. It was hard to warm up the car in the pits with all the cars and the circle track was blocked off so hopefully that's why it picked up. Jeff tested for me and he said he can now make the 1-2 shift so hopefully that is the problem.
I pulled the trans/converter back out on Sunday and sent the converter out yesterday.
Old 05-02-2017, 12:42 PM   #4
Liked 5,139 Times in 1,962 Posts
What kind of computer/ management system?
Old 05-02-2017, 01:14 PM   #5
Jamie4127
All factory Mark. The person who does the tuning is about 2 /12hrs aways. I've been trying to avoid making that that drive just to have him plug it in his computer. But I will if I need too..
Old 05-02-2017, 01:32 PM   #6
Very well could be your problem.There are several limiters in there. Assuming he removed all the transmission programs.
Anyway, more power, more stall, and vice versa.
Old 05-02-2017, 01:42 PM   #7
Jamie4127
I'm sure he did. I've been running this trans I believe for 2 years now w/ no issues. If for some odd reason the converter checks out okay on the dyno I'll get the car back to the tuner and have him check it.
Thanks.
