#11 |
Liked 10,649 Times in 2,208 Posts
Adjust psi until you have an even foot print. 20psi is good to start with.
#12 |
Liked 431 Times in 224 Posts
I can't remember if I'm at 17 or 18 now. I've run everything from 16-26 and they always hook. I only set pressure to get the most even wear across the tire.
30 x 9 Hoosier on 10" wheel at 3,575 lbs.
S/ST 51 S/C 53 |
