Old 04-14-2017, 11:13 PM   #1
jaf2021
Liked 5 Times in 5 Posts
Default Radial tire air pressure
What is common air pressure for a radial tire? I run a 29.5/9 M/T with a 3300 car thanks Jason
jaf2021 is offline   Reply With Quote
Old 04-14-2017, 11:27 PM   #2
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: Radial tire air pressure
I've run as low as 17psi, but the tires want to move on the rim that low. 20psi is where we normally run @ 3000 pounds.
Rich Taylor
I/SA - 321
Old 04-15-2017, 10:19 AM   #3
Kegracing
With Hoosier 30x9 I have ran 18 up to 24 at 3300 lbs. SBC crate motor combo and 305 legal stocker. Used on my 67 Firebird, and also on my 87 Firebird. I really did not see any difference from about 21 to 24 on a good track, 60' or top end. Have heard some going even higher, but I never tried. Lower was better on hot - marginal track.
I have a set of the MT bracket pro's 28x9 on the 67 right now with 427"sbc bracket motor, and while I have limited time on them, really liking them. Very consistent so far, and have hooked very well with the bigger motor even on cold track. Have not really pushed the 60' at all, as looking for good bracket combo.
Radials keep getting better from all the OEM's and much more stable. Don't be afraid to try different setup's for your car.
Good luck,
Ken
Kegracing is offline   Reply With Quote
Old 04-16-2017, 09:23 AM   #4
Patric Fox
Patric Fox's Avatar
Liked 11 Times in 8 Posts
With the Hoosier Radial slicks, I usually run 22psi
Patric Fox is offline   Reply With Quote
Old 04-16-2017, 10:53 AM   #5
Lee Valentine
Liked 319 Times in 68 Posts
Usually 22 in the stocker and super stocker.
Lee Valentine 1661 STK
Old 04-16-2017, 12:55 PM   #6
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Talking Re: Radial tire air pressure
22lbs here also, 3500 lb. car. Jim
Old 04-16-2017, 03:53 PM   #7
Bill Bogues
Bill Bogues's Avatar
Liked 169 Times in 53 Posts
Smile Re: Radial tire air pressure
24lbs with 10 inch rim on 3450lb stocker .........22lbs with 10inch rim on 3250 lb stocker with not as much weight in rear of car.
Bill Bogues 4696 STK
Bill Bogues is offline   Reply With Quote
Old 04-16-2017, 07:31 PM   #8
MIRADA
MIRADA's Avatar
Mine likes 18psi 3400lbs superstocker
Alan Harper
SS/KA 1072
Dodge Mirada
MIRADA is offline   Reply With Quote
Old 04-16-2017, 09:22 PM   #9
HR9121
HR9121's Avatar
I normally run 20 to 22 psi but have been as high as 28 psi on my Hoosiers at 3650 pounds.
James Williamson
W200 J/SA. SS/JA
Old 04-16-2017, 10:18 PM   #10
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Radial tire air pressure
21 lbs with Hoosier 9" lightweight radials on a 10" rim. Usually 1.50 60' at 3,550 lbs footbraking.
LOCOMOTION Racing
