#71 | |
Liked 7 Times in 7 Posts
in Hot Rod Magazine....also recall a Delivery racer with "NHRA hates Sedan Deliveries" lettered on his car.... |
#72 |
Liked 544 Times in 213 Posts
How many times has NHRA made stupid decisions that cost racers a lot of money and time or worse. The answer is a lot ! Just abitrarily make rules or do away with entire categories. Everytime they did this they lost racers. This goes all the way back to the 1960's. Look where they are now....
#73 | |
Liked 48 Times in 44 Posts
Speaking of allowed / not allowed: Thanks to the books I have, HAMB, and this thread!!!, I now have a growing database of stock class (and a few SS and FX) cars from 1950-1971, with the following numbers of et/mph pairs: 186 chev (the most of course) 106 ford (even a few non-427 cars) 80 mopar (about 1/3 hemis) 9 buick (yes, that many!) 30 olds 5 "amc" (includes Hudson, stude) Tedious but fun and revealing. 8 of these are the famous "stock" aka parts counter 383/343 combo of 1962. First run I have is from 1963, last from 1970. Was this combo ever disallowed, is it still called "stock class" today? 6 of the Fords are the 390/335 Comets of 1966. I thought I knew these cars pretty well but the story in this link surprised me- a lot of Ford gurus on that site and nobody disagreed: http://www.network54.com/Forum/74182...47/View+Thread It says the 66 comet 390/335gt was allowed to run the much better aluminum 428 police intake AND functional cold air hood, and at least today, a bigger 735/780 Holley to replace the stock 600 Holley. Of course, Ford had a huge race parts bin, they just didn't use these parts from the factory. So its kind of like the 383/343 story. Anybody know if this is true, WHEN it was first allowed (NHRA disqualified the ram air GTO's at 66 Pomona so why would they allow aluminum intake Comets?), and WHY it only applied to the 66 Comet, and not all the other FoMoCo 390gt engines of 1966-1968? |
#74 | |
Liked 72 Times in 36 Posts
#75 | |
Liked 50 Times in 28 Posts
#76 | |
Hi Dwight et al yes I am still working on my old 1960s NHRA compilation. There is another pair I am having trouble with, maybe you have a way to look up the NHRA weights and (Factored) HP for these cars back circa 1964-65. Two engines: * MaxWedge 426/425 - I am assuming this was not factored so stayed at 425 even though it made a bit more than that. * 427/425 HiRiser - I am using a factored HP of 465 just to make things fit but that is a guess. Today's NHRA factors the HiRiser between 420-460 hp depending on class. Reality was it was over 500 hp even back in 1964-65, so I wondered how NHRA factored it back then. Car weights: Mainly looking for what NHRA said back in 1964-65 about the LightWeight Galaxie (LWG). NHRA today has the 1963 LWG at 3320 lb, and the 1964 LWG at 3748 lb. The bodies are near identical, so that's over 400 lb of difference. I know some of the lightweighting parts changed but here is my logic in asking this stuff: * The meager real 1964-66 data I have on the 64 HiRiser LWG shows speeds of 121 mph for the auto trans (a doggy Lincoln unit) an 123-126mph for the stick car. That's getting up there near Thunderbolt speeds, so I wondered if the car was really as heavy as 3750 or if the old spec was different. * In Larry Davis' book, I know he is not a Ford buy but he says on pg99: "However, the LWG fell right into the extreme top of AA/S, where they not only were competitive, they dominated". Well, I get a W/P of 3748/465=8.06, which is a long way from being at the top of the AA=7.00-8.69 class. So either the 64 LWG spec was quite a bit lighter than 3748, or the factored HP was quite a bit more than 465, or the quote is just wrong. Wondered if the OLD NHRA weights and factored HP could shed any light on this. Thanks for your patience for those who read this far. |
#77 |
Liked 783 Times in 195 Posts
Interesting points that you bring out. Here is what I have found in the 1970 Classification Guide
1963 LWG is the same as currently listed. 7.82 factor and 425hp. That makes the shipping weight 3324 for a Galaxie 500 2dr hdtp. Probably the published weight to NHRA was 3325, but so goes rounding. I have seen the claimed shipping weight to be 3270 and 3300 in other publications over the years. An interesting fact about these cars is that the LW components were available on a wide variety of car models and body styles, from a 300 2dr sedan to a Galaxie 500 XL 2dr hdtp. 1964 lightweight component car. Only listed for a Galaxie 500 2dr hdtp. The current factor of 8.93 and 420hp makes the shipping weight 3750 lbs. In the 1970 Class Guide, the factor is 8.33. If the power rating back then was 425, then the shipping weight is 3540 lbs. However, I have no documentation that tells be what the engine was rated back then. But, if you assume that the 3750 shipping weight is correct, then the power rating was 450 (3750 / 450 = 8.333...), which in probably the case, since the Thunderbolt has a power-to-weight factor of 7.13 in the old book, and that would have the shipping weight at 3208, very close to the 3206 calculated from today's Class Guide.
#78 | |
Thanks again Dwight that confirms what was said over on fordfe.com. Two folks over there had a 64 LWG and confirmed the car was 3750 with no driver, and could make that weight almost full of gas too. The old factor they remembered was 450-460hp (450hp in the 1973 book). The 460hp makes sense as an earlier factor, because using "only" 450hp would have put the Thunderbolt into AA/S, so NHRA probably rated the engine at 460hp deliberately just to put the Thunderbolt barely into S/S with the Hemi, so the big Galaxie stayed in AA/S. 450-460hp seems low for a prepped 427 HiRiser, but as I Gonkulate both engines, 425hp was equally low for a 426 MW Stage 3. Both of those are factored at about 80% of what they actually made as prepped, to turn the MPH they turned. I am finding that to be pretty much true, whether its the Tri-5 283s, the LM1, the z28, the 427 HR, the MaxWedge, etc, a "winning" combo engine typically was only NHRA rated at 80%-85% of what the prepped engine actually Gonkulates to. If the engine was overrated, of course the combo would not win. But even if it was rated "right on", it would still lose out - there were so many good combos way underrated (80%-85%) that they dominated most of the classes. |
#79 | |
Dwight, I am still working away, up to 1967-70 now and struggling with all those 400 Pontiacs. Wondering if you have time to look up some factors circa those years. I'm assuming from the above that all the 400ra4, Firebird and Tempest, were factored to 380hp. I am using that 380hp also for the 1968-1/2 Ra2 cars since that "fits" the cars that ran and the engines were so similar. It seems from 1967-70, Pontiac had a zillion 400's. The stick and auto cars had different cams but the same rated HP. The Tempest and Firebird had the same engines (well at least when they were uncorked for NHRA with open headers & throttles) but the Firebirds were all rated lower. IN GENERAL, did NHRA up-rate all the Firebirds to their equal Tempest-engine ratings? (It seems the current guides do this but I wonder if they did that right away back in 1967-70 ?) eg 1967: Was the "325hp" Firebird RA1 up-rated to the "360hp" Tempest RA1 rating? (which I assume was left as-is at 360)? Were both the stick and auto cam engines left with the same rating? 1968: So, was the "335hp" Firebird RA1 up-rated to the "360hp" Tempest RA1 rating (which I assume was left as-is at 360)? Were both the stick and auto cam engines left with the same rating? 1968-70 Was the base "330hp" Firebird up-rated to the base "350hp" Tempest rating? Oddly, today's NHRA rates the 1968 Firebird base "330hp" at 338hp auto, 325hp stick, even though the auto engine had the smaller "066" cam. 1969: Was the "335hp" Firebird RA3 up-rated to the "366hp" Tempest RA3 rating? 1970: Was the "345hp" Firebird RA3 up-rated to the "366hp" Tempest RA3 rating? It seems like, unless the Firebirds were "uprated" to the Tempest ratings, why would anybody ever race a Tempest when the Firebirds has this built-in advantage? Sorry to be such a bother, trying to make the history as accurate as I can as I try to "Gonkulate" all these cars. Last edited by DeuceCoupe; 12-23-2016 at 12:35 AM. |
#80 |
Liked 2 Times in 2 Posts
i have a copy of the record page from nat dragster from 1968--1972 if you want a pic. let me know-gary
