Old 08-27-2016, 10:19 AM   #1
Liked 5,121 Times in 1,952 Posts
Default Re: Trans weight - turbo 350 vs 200 metric
Originally Posted by Jim Hanig View Post
How about a PG and the 200.
Very close to the same, depending on what options they are fitted with.
Old 08-28-2016, 11:08 PM   #2
Greenlight
Liked 79 Times in 22 Posts
OEM weights
http://www.probuildamerican.com/wp-c...ions-gm-th.jpg
Greenlight is offline   Reply With Quote
Old 08-29-2016, 08:01 AM   #3
Lou Jeffery
Assuming we are talking about Stock and Superstock the overall vehicle weight needs to stay the same, lighter transmission must adjust with ballast. The big difference would be any parts of the transmission that rotate. The 350 has a heavy large valvebody, heavy pump assembly and a iron low roller support. These parts just go for the ride and do not rotate. Has anyone compared 200 - 350 internals?
I know this question has been asked before without very clear answers, "How much does a Stocker pick up by replacing a race prepped 350 with a race prepped 200?"
Lou Jeffery is offline   Reply With Quote
Old 08-29-2016, 10:10 AM   #4
pfordamx
Liked 7 Times in 5 Posts
Even though the car has to remain the same weight at least if you took it out of the transmission you could put the weight where you want it, and that may not be much of a advantage but it i'd say it counts for something.
pfordamx is offline   Reply With Quote
Old 08-30-2016, 02:29 PM   #5
Alan Nyhus
Liked 799 Times in 236 Posts
My Powerglide and Metric 200 were within 2 lbs. of each other with similarly lightened internals.
"That'll never work....."
Old 08-30-2016, 03:40 PM   #6
James Perrone
Liked 1,821 Times in 425 Posts
The metric has a better 1st gear than the 350 or power glide
james perrone 1290 STK
Old 08-31-2016, 01:46 PM   #7
Jim Hanig
Liked 99 Times in 49 Posts
Mark which trans do you think would be better in a 3200 # car. the 2.18 pg or 2.52 350, both are very good race trans. ?? thanks Jim
Old 08-31-2016, 02:14 PM   #8
Cu. in., stroke, rpm range?
Old 09-13-2016, 06:33 PM   #9
Jim Hanig
327 super/stock engine
