Old 08-19-2016, 10:11 AM   #1
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
Default Re: 4-spd Transmission Choice for lower class Ford US/VS/WS
The T-bird Turbo Coupe had the 3.97 low gear in the T-5 , but I'd probably go with the V-8 World Class deal. with the closer ratios.
You are pretty much going to have to go with a 9" to get the strength and the ratio you will need anyway.
My experience with the T-5 is that they don't like to be power shifted above about 6 grand. You will probably have to slick shift 2 ,3 , and 4th to make it work, plus remove the heavy o/d gear in the tail.
Then you'll need a B&M or similar short throw top shifter.
The first time you go from 2nd to 5th, you will then have to make some kind of swing away lock out so you can still use reverse.
The T-5 is not and ideal situation, but probably the smallest and most efficient deal that you could get away with.
Pic is not the best but all I could find.
what about a 8.8"? might use less hp than a 9"...
Old 08-19-2016, 10:41 AM   #2
PROSTOCKTOM
PROSTOCKTOM's Avatar
8.8" would probably use less HP, but he already has a good supply of 9" parts.
Plus it's easier to change if we break one at the track.
Back to the transmission discussion
Tom
PROSTOCKTOM is offline   Reply With Quote
Old 08-20-2016, 12:18 PM   #3
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: 4-spd Transmission Choice for lower class Ford US/VS/WS
Tom
How in the world would you break a 9 inch with a Pinto motor?The 8.8 would be the logical choice due to size,weight,cost and availability. If 6.14's are available, so would anything else you would need.The 8.8 uses some of the same internal bearings as a 12 bolt.It would definitely be more low friction than the 9 inch.
Old 08-20-2016, 01:03 PM   #4
Greg, Of course the 8.8 would seem like the logical choice. However, all the different ratios were not available (in the 5. -- range anyway) last time I looked into this.
However, if a 6.14 is available, here's what I came up with.
First of all, I try to set up a class car to be able to run 9-10 under.
That way, it leaves room for improvement if you don't have the beans under the hood to run that at first. At least you will know where the problem lies.
So, W/Stock is a 16.40 index.
Let's shoot for 15.50. I know that you will have to run pretty close to 85 mph to go that quick.
Using a 26 x 8 MT tire, and a 6.14 gear, 7000 in the lights would be about 88 mph.
Trust me ..7000 is not too high for a non turbo 2300. Probably not high enough.
With the 6.14's , at that weight , you wouldn't need a super low first gear. Just a bit of flywheel weight to carry it out smoothly, and all the rpm you want.
That's my take... FWIW
Old 08-19-2016, 12:33 PM   #5
Need lower than a 5.13 in that combo , I believe.
Old 08-19-2016, 01:36 PM   #6
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
A 5.71 is available for the 8.8. Finding the right tire to get the RPM in the traps may be a challenge. The 9" would be a heavy and power robbing way to go. 8.8's may not have optimal gear choices or be soft gears, but they hold up behind a V8 stick car for many years before stress fractures occur.
The adapter plate was used in a stocker mustang with a Jerico and even won class at Indy a few years ago, along with setting a few records along the way. A couple of SVO's were in competition too. I do not know what trans the SVO's were running and may still be competing. One has switched to a different year and auto, the other was a D4 car. If they were running a 5.0 clutch and flywheel the adapter plate is needed for the bigger bellhousing otherwise there isn't an adjustable clutch made for that application.
What's the biggest tire that will fit the wagon?
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 08-19-2016, 04:12 PM   #7
ALMACK
ALMACK's Avatar
Liked 373 Times in 131 Posts
Sean
I had to re-read my 2016 rulebook again Sean.
Sure enough, I did not see anything prohibiting adapter plates.
I'll check my 2014 and older rule books, but I thought for sure I saw it printed at one time that transmission adapter plates were prohibited in Stock.
At any rate, that's good news.
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 08-19-2016, 04:34 PM   #8
Sean Marconette
Your not loosing your mind Alan!!! It has been posted at sometime because I have seen it as well, I just don't know where or when. Hope all is going well,
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 08-19-2016, 11:15 PM   #9
PROSTOCKTOM
Sean
He has some 24" tires and we had a 26 x 8" under it on a 7" rim. Might be able to get more if we worked on it a little here and there, but 26" looks really big in that wheel well.
Also I have now found out that you can get a 6.14 in a 8.8" gear.
Not sure what else is available from the previous thought limit to the 6.14 or if there is an even deeper ration available yet.
Tom
Old 08-20-2016, 01:23 AM   #10
Tom Moock
Liked 10 Times in 6 Posts
Sean, 2004 rule book,Under automatic transmission, NHRA-accepted adapter plates permitted.
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
