Old 06-13-2016, 01:52 PM   #1
pfordamx
Liked 7 Times in 5 Posts
Default 70 amx 360 carb
can anyone clarify what the blue print sheet is saying under carb for 1970 290hp 360 amc combo becuase i think it should be a autolite 4300 4bl but all the blue print sheet says is (owa-4/auto) i'm pretty positive the /auto is specifying a automatic trans and i've looked through the accepted parts list and didn't see a reference to this. any help would be appreciated
(290 360 10.0 1-4 Ford 0WM-4/SM 0WA-4/AUTO)
pfordamx is offline   Reply With Quote
Old 06-13-2016, 02:05 PM   #2
DeuceCoupe
Liked 48 Times in 44 Posts
Default Re: 70 amx 360 carb
I have run a lot of Ford 4300's so now & then I obtain an AMC 4300.
AFAIK, AMC used the Carter AFB thru 1969, then went to the Autolite 4300.
Ford made 2 sizes for the 4300:
1.00" venturi, about 440cfm
IIRC this was only used from 1967-69.
1.25" venturi, about 600cfm
This was used from 1968-1974.
In the AMC numbering, 1st digit is the year, 3rd digit is a=auto or m=manual, and I think last digit means 4bbl.
I've had:
3tm4
3ta4
4ta4
I don't know what the 2nd digit "T" vs your "W" means.
All the 1.25" venturi Autolite 4300's are the same CFM so I bet any of them would be legal, the only diff is jets & air bleeds etc.
Old 06-13-2016, 02:07 PM   #3
Bobby DiDomenico
Liked 101 Times in 52 Posts
Have a friend who moved to Phoenix a while back with 2 AMC's. Isn't this the same 600 cfm carb on a 70/71 351 Ford?
0 = 1970 W = engine size M = Manual & A = Automatic 4 = 4V
Old 06-13-2016, 03:23 PM   #4
pfordamx
i think it is the same 600cfm carb that ford used and that being the case do you guys have a builder you would suggest? i know Deano is the man on quadrajets , so who knows autolites also makes me wonder if there is a quickfuel or replacement option but i haven't seen one.
it would be great if i could use any 600cfm carb i wanted.
Old 06-13-2016, 03:27 PM   #5
pfordamx
and i guess its a motorcraft not a autolite unless there the same i don't know fords that well.
Old 06-13-2016, 03:33 PM   #6
Bobby DiDomenico
Somewhere before or by the early 70"s I recall my boxes going from Autolite to Motorcraft at the local Ford dealer.
Old 06-13-2016, 05:55 PM   #7
rawhide
during the 60's Ford used Autolite as a trade name for a lot of parts. The government for some reason sued Ford and made them sell the spark plug division so Ford started using Motorcraft for their parts and Fram/Allied Signal ended up with Autolite.
Roland
rawhide is offline   Reply With Quote
Old 06-14-2016, 06:03 AM   #8
GTX JOHN
The best Autolite Carb guy I know is George Thompson "Carburetor Flow
Engineering". I can look up his number if you want. His cars are always
near the top of the field out here in the West!
John Irving
741 Stock
741 Super Stock
Old 06-14-2016, 07:30 PM   #9
Greg Hill
Liked 279 Times in 68 Posts
It's not a 780 Holley!
Greg Hill 4171 STK
Old 06-14-2016, 09:48 PM   #10
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Got that right Greg !
The OWA4 /OWM4 is a Motorcraft 4300. A temperamental sumbitch of a carb that works good with a stick and fair on a 2 step automatic . unpredictable on a foot brake .
Most Ford 351 racers run the Holley where it's accepted as a replacement and take the HP ,but a few stick racers run it successfully.
Deuce Coupe has the correct info on the sizes and GTX John is right ,Thompson did the carb I ran on my D/S Automatic '70 AMX, Worked as good as you can get from that carb.
Tom Goldman is online now   Reply With Quote
