Liked 7 Times in 5 Posts
and i guess its a motorcraft not a autolite unless there the same i don't know fords that well.
Liked 101 Times in 52 Posts
during the 60's Ford used Autolite as a trade name for a lot of parts. The government for some reason sued Ford and made them sell the spark plug division so Ford started using Motorcraft for their parts and Fram/Allied Signal ended up with Autolite.
Roland |
Liked 2,483 Times in 697 Posts
The best Autolite Carb guy I know is George Thompson "Carburetor Flow
Engineering". I can look up his number if you want. His cars are always near the top of the field out here in the West!
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 06-14-2016 at 06:05 AM. |
Liked 279 Times in 68 Posts
It's not a 780 Holley!
Greg Hill 4171 STK |
Liked 881 Times in 236 Posts
Got that right Greg !
The OWA4 /OWM4 is a Motorcraft 4300. A temperamental sumbitch of a carb that works good with a stick and fair on a 2 step automatic . unpredictable on a foot brake . Most Ford 351 racers run the Holley where it's accepted as a replacement and take the HP ,but a few stick racers run it successfully. Deuce Coupe has the correct info on the sizes and GTX John is right ,Thompson did the carb I ran on my D/S Automatic '70 AMX, Worked as good as you can get from that carb.
Liked 2 Times in 2 Posts
In 1974,I bought a,1970 Javelin SST 360 auto,Mark Donahue signature car big spoiler, factory cold air hood for 1500 dollars. It had a carter AVS I always thought that was the original carb.
