Old 12-12-2007, 05:49 PM   #1
castle5
Default Re: Two/three step wiring/functions(stick cars)IHRA!
most class racers are shifting clutchless. i use clutch on every gear change and ive got a clutch lever mounted switch and ive never had a problem with rev liniter coming on during shifts. i just tap the pedal anyhow. on gear changes...i guess it depends on your driving style...try it first
castle5 is offline   Reply With Quote
Old 12-12-2007, 07:34 PM   #2
Rod Greene
Liked 242 Times in 81 Posts
Ok Castle so at the end of your run you just back off the throttle and pull off the track? I push the clutch in oops just went from 8000 rpm to 6500 (if I had a swich on the clutch) and coast off the track. Several stick racers talked to Bruce at the Vegas national race. We thought he understood the problem or lack of one as pertains to the line lock two step issue for stick cars obviously it didn't make it to the rules makers. We need racers involved in the rules process and not just the sludge-o-matic racers.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 12-12-2007, 08:18 PM   #3
terry1
Liked 24 Times in 13 Posts
Question Re: Two/three step wiring/functions(stick cars)IHRA!
Is it possible that if us stick guys(and gals) got together and individually sent our concerns to IHRA(don't get me started with nhra) they may actually listen?
terry1 is offline   Reply With Quote
Old 12-12-2007, 10:46 PM   #4
race watcher
It is possible to mount a micro switch on either shifter or trans lever to only energize the two step in 1st gear.
race watcher is offline   Reply With Quote
Old 12-13-2007, 12:07 AM   #5
Stick Racing
(11/15/07) The two or three step must be mounted on the brake or clutch petal on all entries. The function may not be actived or deactived by any other switch on the car.
The way I read it, that's not legal.
Andy Stone B/S 1102
Stick Racing is offline   Reply With Quote
Old 12-13-2007, 12:36 AM   #6
Jeff Lee
Jeff Lee's Avatar
I think NHRA doesn't understand stick racers are not the problem (perceived or real) with the two step buttons. Long travel buttons have no place in a clutch environment as you wouldn't want a delay in releasing the two-step after engaging the clutch disk which typically have a .035" to .075" air-gap. A 3" travel two-step button obviously has no place here. The problem you would run into is a two-step activating early or late as a result of a improper micro-switch adjustment. To early and the RPM goes to the next stage of the two-step and you hit the clutch engagement to hard. To late and the clutch engagement occurs on the two-step and their is less power at the crankshaft possibly causing too much slippage.
Stick racers should have a choice between running two switches (one for linelock, one for two-step) or tie both together as traditionally done (usually with a single button on the shift handle) as long as all wires are visible and easily traceable. I think NHRA doesn't understand stick racers are not the problem (perceived or real) with the two step buttons. Long travel buttons have no place in a clutch environment as you wouldn't want a delay in releasing the two-step after engaging the clutch disk which typically have a .035" to .075" air-gap. A 3" travel two-step button obviously has no place here. The problem you would run into is a two-step activating early or late as a result of a improper micro-switch adjustment. To early and the RPM goes to the next stage of the two-step and you hit the clutch engagement to hard. To late and the clutch engagement occurs on the two-step and their is less power at the crankshaft possibly causing too much slippage.
I'm copying this to Len Imbrogno. (Limbrogno@nhra.com)
Jeff Lee 7494 D/S '70 AMX
Old 12-13-2007, 10:03 AM   #7
terry1
Thumbs up Re: Two/three step wiring/functions(stick cars)IHRA!
Well said Jeff.Hope you will keep us up to date on any correspondence that even has the "look"that some one is listening.Imagine the concept that an organization like IHRA listening to what members have to say.If it happens that they do listen,nhra might learn a thing or two from IHRA,woundn't that be something.
I like your coment about wiring out in the open for all to see.I think IHRA officals would sure rather do that than try to trace endless contacts on multi contact relays.
