Old 12-20-2015, 03:44 PM   #1
Eman
Liked 133 Times in 76 Posts
Default Re: Racing seats
I welded some threaded inserts into the floor pan similar to the stock seat mounts. I drilled the threads out of the seat inserts an used a 3/8 grade 8 bolt with a large flat washer to bolt through the bottom of the seat to the floor. 1 half inch bolt through the back into the cross bar
OK, so you actually have the seat sitting on the floorpan? I sandwiched the floorpan between 2 pieces of steel but mad seat mount brackets under the seat that are adjustable for tilt.
Are stock factory seat adjusters legal? I've had a car with a poly seat that had the poly seat bolted to the adjusters.
Old 12-20-2015, 04:02 PM   #2
Adger Smith
Liked 880 Times in 311 Posts
I have one of the last Gen 3's that Ed Quay did, himself. I plan on finishing it sometime in 2016. It was delivered with Kirkey alum seats on what looks like a stock bucket seat adjuster/slides. The back of the seat support is built to attach to the roll cage cross bar and adjusts as the seat adjusts. I would assume he wouldn't build a car for NHRA Super Stock that didn't fit the rules.
Adger Smith (Former SS)
Old 12-20-2015, 06:10 PM   #3
Adger Smith
oops double hit
Old 12-21-2015, 09:04 AM   #4
Mike Pearson
Mike Pearson's Avatar
Liked 2,013 Times in 604 Posts
Yes my seats are bolted directly to the floor. I have a gen 1 Camaro and the floor below the seat is heavy double steel so it makes a good solid install. I am tall so I need the head room. I am also the only driver so no need for adjustable mounts.
Mike Pearson 2485 SS
Old 12-21-2015, 09:08 AM   #5
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Originally Posted by mike pearson View Post
yes my seats are bolted directly to the floor. I have a gen 1 camaro and the floor below the seat is heavy double steel so it makes a good solid install. I am tall so i need the head room. I am also the only driver so no need for adjustable mounts.
X2 Only I have a GM "A" body not a gen 1 camaro....
Old 12-21-2015, 09:26 PM   #6
CMcAllister
Liked 931 Times in 265 Posts
In the Chevelle we just did, it was a factory bucket seat car and we used the OE seat mounting points. It's a reinforced hard point, so we used that. But the centerline of the mounting points is not centered on the steering wheel and the seat had to be adjusted over with the mount to center it on the wheel. The Jaz seats we used are mounted about 2 1/4" from the floor to the bottom of the seat to get the best height for visibility, fitting in the cage, etc. We just determined where the seat would need to be and fabbed a CM tubular mount between the floor points and the seat. Made a mirror image piece for the passenger side and made a seat back brace attached to the crossbar..
Old 12-23-2015, 09:41 AM   #7
R. Thorne
Liked 107 Times in 35 Posts
Thanks to all who responded. Much appreciated. Ron.
R. Thorne is offline   Reply With Quote
