#21 |
Liked 780 Times in 194 Posts
#22 |
Powerglides. Robert "Hutch" Hutchison was one of the first I remember making one fast in Div 4.
Personally, I broke a lot of 3 speeds in my '56 around that time. Took me a while to get my head out, and soften up the clutch.
Ed Wright 4156 SS/JA Last edited by Ed Wright; 09-29-2015 at 08:11 AM. |
#23 |
Liked 254 Times in 78 Posts
Anyone have an opinion on whether to use the power valve in these or block it off. I have a Deano carb and it is blocked off, haven't tried to 'restore' it to a power valve setup.
Mike Moller NHRA 203 Q-R-T/SA |
#24 |
Mike, How high are you foot braking it?
#25 |
Bad air 3000, good air 3500. By the way, just installed Kenny's converter today. With the old converter, 3500 was really wanting to push the brakes. Car was .04-.06 slower at 2500.
Mike Moller NHRA 203 Q-R-T/SA Last edited by MikeMoller; 09-29-2015 at 12:29 AM. |
#26 |
Liked 2 Times in 2 Posts
Mike, you'll go nut's trying to use a pv in a roch. 2gc carb as they had so many deravations of the pvrc they used.. Plug it, retap the jetting holes and use the holley jetting, better selection and easily obtainable. Tip:, now your ready to begin playing with the fuel curve !!!!!!! (assuming you have a good wide band data logger).
#27 |
I don't think you need to worry about a power valve then.
As long as it drives around the pits okay...
#28 |
No issue in the pits. Thanks. Will know this weekend if the converter helps- it should be a little looser.
#29 | |
Ed Wright 4156 SS/JA |
#30 |
Found a good source of 2GC part including jets-Mike's Carburetor Parts. Has everything for 2GC's.
http://www.carburetor-parts.com/Rochester_c_31.html
