Old 01-31-2014, 01:27 AM   #11
pro stock chuck
pro stock chuck's Avatar
Liked 53 Times in 17 Posts
Default Re: Schubeck lifters
sorry your info is not accurate
here the deal bob smith made the first gen lifter for the first year or so then schubeck move over to different suppliers (cutting cost) and here came the failures. this is accurate. your welcome
pro stock chuck is offline   Reply With Quote
Old 01-31-2014, 08:38 PM   #12
Jim Hanig
Liked 99 Times in 49 Posts
Well I have seen 4or 5 failures last year, sent 1 set back after one failed he check them sent them back 10 later another one failed. I would sell them cheap if your brave enough
Old 09-04-2015, 09:39 AM   #13
Al Reed
Liked 2 Times in 2 Posts
We had SM Lifters (not Schubecks), a puck got scared of 9K+ rpms and decided to leave, did a fair bit of damage. This was at a pro's shop being dynoed when it occurred.
Rights springs, right everything, lifter just flat out failed. Cost a bunch to fix it all....
Al Reed is offline   Reply With Quote
Old 09-04-2015, 03:02 PM   #14
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Wow 9K+ rpm for a flat tappet cam and lifters. What kind of spring being used for that application. Just want to know that combo.
Glenn Briglio is online now   Reply With Quote
Old 09-04-2015, 04:02 PM   #15
Dyno
Dyno's Avatar
Liked 693 Times in 205 Posts
I was at a dyno session with a new 426 max wedge. 5th or 6th pull there was a quick miss in the engine and immediately the engine was shut off. Completely destroyed the new maxie. Needed new pistons and a complete rebuild. A puck had come off one of the new lifters. I would not use them, but many racers have had good luck with them. Good luck to you! Dyno
Old 09-04-2015, 04:45 PM   #16
John Dinkel
Liked 263 Times in 68 Posts
Thumbs up Re: Schubeck lifters
Jim, I have been running them for years with no problems. Installed 5 or 6 cams and ran them flat out.
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 09-04-2015, 06:31 PM   #17
MR DERBY CITY
Liked 8,032 Times in 1,527 Posts
Schubeck lifters.... Buyers beware, A large number of racers have ran them with NO problems, However if they fail they take a lot of good parts with them . Risk vs. Reward ? .....M.J.
Old 09-05-2015, 01:36 AM   #18
GTX JOHN
We have had a bunch of trouble with them......Smith's too!
I have several near new sets of Smith's Hyd. and the punks can be
removed easily by pulling them out of housing. i am scared to use them.
Can the punks be safely glued back in? I am scared to try....... Smith's
never answers the phone or returns my calls.
Apparently my business means less than nothing to them.....In last 10 to 15 years I have bought no less than 12 sets. they were better when I first started to use them and got them from Schubeck right at his shop in Vegas.
Of nearly a dozen sets........About 4 sets broke!!
John Irving
741 Stock
741 Super Stock
Old 09-05-2015, 09:55 AM   #19
Liked 1,868 Times in 422 Posts
We have never hurt a Schubeck without another failure coming first. However, the first and only business dealing I had with Schubeck was very bad. That said, we/I have not run any of Smith's, but a lot of people I know who are extremely well versed in Stock Eliminator engines have lost Smith's lifters, not likely through any fault of anything but the lifter. Had even worse dealings with PPPC. That's the reason I use and sell Trend tool steel lifters now, after nearly 4 years of selling more than two dozen sets as a small low volume dealer, I've not had anyone complain of a failure, and most have bought more than one set.
Old 09-07-2015, 11:40 AM   #20
Greg Reimer 7376
Liked 719 Times in 220 Posts
Question Re: Schubeck lifters
Sounds good to me. I've had no problems with Smiths yet, but the tool steel setup sounds a lot more reliable. Does anything have to be done to the camshaft?I have Bullet steel billet cams in both my motors, nice pieces, but I don't need glass fragments all through the place. Who sells the Trends and are they just a drop in replacement for the Smiths?
