Old 01-18-2014, 08:04 PM   #1
treessavoy
Liked 4 Times in 4 Posts
Default Schubeck lifters
What's the proper break-in procedures for these lifters on a solid lift cam? Oil, rpms, spring pressure, etc.
This is my first times using these and I have been told that break-in is much like break-in using roller lifters, is that correct?
JimR
Jim Rountree
Old 01-18-2014, 08:24 PM   #2
randy wilson
Liked 22 Times in 22 Posts
Default Re: Schubeck lifters
There is no break in procedure. But unless you have the full ceramic solids, I'd be very careful with the solid, or hydraulic ceramic bottoms. Cost me a good engine.
don,t have one
Old 01-19-2014, 12:00 AM   #3
Jim Hanig
Liked 99 Times in 49 Posts
JimR
What ever you plan to race with CK the lifter bore .0017 to 002 and keep up with the pressure
Old 01-19-2014, 01:52 PM   #4
Todd Hoven
Guest
Posts: n/a
No break in proceedure, set the valve adjustment and run em.
Be aware if and when your engine is in valve float, and run enough spring pressure. Nothing wrong with these if you pay attention. Many racers run these for a long time with positive results.
Old 01-22-2014, 01:55 PM   #5
Robert Simpson
Liked 20 Times in 12 Posts
Jim, as the other said no brake in necessary. What we did when we did a cam change was take a spring shim out, warm the car up a couple times, checking things as we went. Then installed the shims back in to put the seat pressure where it needs to be, then run it. I know these steps are not necessary but I was extra cautious. We run a sbc, hyd set up. I know it is a different combo, but we run shubecks.
Robert
Robert Simpson is offline   Reply With Quote
Old 01-22-2014, 08:18 PM   #6
treessavoy
Thanks guys,
Application is max wedge, solid cam
JimR
Jim Rountree
Old 01-23-2014, 09:23 AM   #7
Casey Miles
Liked 508 Times in 92 Posts
I just had a Schubeck lifter loose it's puck, the engine got f**ked. Never put them in any engine again. Use tool steel lifters for now on.
Casey Miles
248H "F" NHRA Stock!
Old 01-30-2014, 01:11 PM   #8
Duane Eiskant II
Duane Eiskant II's Avatar
Liked 57 Times in 33 Posts
Like Todd said you have to stay on top of spring pressures with the puck style lifter. If you dont the cams are so aggresive these days it actually throws the lifter off the lobe, when it comes back down and makes contact the puck gets knocked off. Im extra cautious about spring pressures simply for that reason and probably have WAY to much, but (knock on wood) ive used the same schubecks that Jeff Velde gave me 10 years ago that came out of one of his engines. Same thing applies for the roller lifters, thats the reason they break the wheels off, not enough spring pressure and everything starts bouncing.
Duane Eiskant
1354 Stock/Super Stock
Duane Eiskant II is offline   Reply With Quote
Old 01-30-2014, 02:01 PM   #9
pro stock chuck
pro stock chuck's Avatar
Liked 53 Times in 17 Posts
Arrow Re: Schubeck lifters
Warning!!!!!!!!!!!!!!! if these are Schubeck dont use them. With Schubeck you dont know if they are the US made or the overseas ones you could have a real problem on your hands. If they are the Smith Machine ones your good to go. Chuck
pro stock chuck is offline   Reply With Quote
Old 01-31-2014, 12:49 AM   #10
Jim Hanig
Not true the Smith lifters have almost the same failure rate. think smith made the bodys or subecks.
