Liked 288 Times in 109 Posts
Liked 1,599 Times in 583 Posts
It's not legal.
The air cleaner rule you have to follow is the same as for Super Stock class. AIR CLEANERS Optional. If used, air cleaner must be OEM automotive or retain OEM configuration. Air-cleaner base may be cut or trimmed, but welding, bolting, riveting, epoxying, or any other form of fabrication prohibited. Ram tubes, velocity stacks, or other than stock-type base plates or ducting prohibited. Cooling holes prohibited in radiator side panels, etc. Factory air cleaners and/or scoops that fit through hood must be affixed to carburetor as per OEM only. |
Liked 5 Times in 5 Posts
X2,,, that's basically a velocity stack you're looking at, Larry.
Danny Durham |
Liked 285 Times in 87 Posts
Larry…Classic Industries Part number C695, should keep you out of trouble. MB.
Liked 99 Times in 60 Posts
Maurice,
Thanks, I need a non trouble situation ![]()
Larry Woodfin 471W |
Liked 110 Times in 29 Posts
Larry,
Not sure exactly what you are wanting but if you need an air cleaner base, then check out Speedway Motors' #91011062-2. At only $14.99 you can't go wrong. This is what I used to recommend to my carb customers when they asked about air cleaner bases. They also offer it with a top if you want to run a filter, #91011000. It comes with your choice if spacer 1/2, 1, or 2 inch and a stud. Hope this helps. Regards, Danny |
Liked 33 Times in 16 Posts
Legal? http://www.r2cperformance.com/produc...?ProductId=264
http://www.speedwaymotors.com/R2C-Pe...-14,70686.html
Rich Taylor I/SA - 321 Last edited by HandOverFist; 08-12-2015 at 09:22 AM. |
Liked 799 Times in 236 Posts
I think tech. would consider that base the same as they do a K&N Stub Stack. -Al
"That'll never work....." |
#9 | |
How about this version? These folks are supposedly working on Quadrajet parts as well. ![]()
Rich Taylor I/SA - 321 |
Danny Ashley,
Thanks, I still remember the very good Q-jet you did for me about 8 - 9 years ago. That carb worked great on our 350/255 F/SA Nova. And about the air pan base, simply looking at something to potentially smooth out air flow. I will check your suggested links. The combination I have now is SS 327/300/293 with Quick Fuel SS585 replacement carb.
