Old 06-20-2015, 01:48 PM   #6
JohnRoderick
JohnRoderick's Avatar
Liked 11 Times in 4 Posts
Default Re: Bellhousing alignment issue
Originally Posted by Sean Marconette View Post
On my old Lakewood bellhousings, I installed the welded style like these.
http://www.summitracing.com/parts/lak-15981
With the welded style, when the bellhousing is installed and the alignment is where you want it. With all fasteners installed and tight, then all you have to do is tack the weld bushings. Not enough heat to change the alignment.
Or as suggested buy a Browell. Best money I have ever spent.
Good Luck
Sean
Buying the Browell was the first step of the whole process. Now I just need to find a solution for the dowell pins.
JohnRoderick is offline   Reply With Quote
