Old 06-14-2015, 10:39 AM   #18
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Default Re: Stocker Tech Rules Gas Tank & Battery?
Originally Posted by Painter View Post
Bob, you are almost right. The requirement for the grounding wire from the filler to the car does not apply to aluminium tanks.
Bob is correct.
In D5 it does. As I had to install a ground wire on my aluminum cell. The point the tech made was there is a gasket between the filler and the cell. It was not worth arguing about, so I installed a ground on the cell. Although the bolt that secures the filler to the cell contacts the cell and filler, and my cell is bolted directly to the floor of the car.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Sean Marconette is online now   Reply With Quote
