Old 06-08-2015, 10:38 PM   #3
MikeMoller
MikeMoller's Avatar
Liked 254 Times in 78 Posts
Default Re: Stocker Tech Rules Gas Tank & Battery?
NHRA 2015 Rule book under Stock
GAS TANK
Must be correct year, make, and model for car used, with stock
fuel inlet and outlet locations. Must be in stock location; fuel line
and pickup may be resized. Fuel cell permitted; maximum capacity
16 gallons. If fuel cell is used, OEM gas tank must be removed,
and a firewall of minimum .032-inch aluminum or .024-inch steel
must be installed to totally seal driver compartment from fuel cell.
Trunk floor may be modified to accommodate fuel-cell sump.
Where OEM gas tank is in the trunk floor, area occupied by OEM
tank may be replaced with material equal to or heavier than OEM
floor. If OEM gas tank is used, it must remain unaltered.
Mike Moller
NHRA 203 Q-R-T/SA
