#11 |
Liked 11 Times in 8 Posts
Can't really say I prefer any brand wire...Firecore makes what is probably the quietest wire out there, but again I would say your MSD wires are probably not the cause of the problem just yet. So you're saying the strobe is on all the time never flashes? WOW that would require A LOT of noise, any chance your coil wire is near where you're hooking up? that one is hot nearly all the time with engine running. I'd try seperating the wires out as far as I could, leave all other components off (water pump fan ect.) and try again.And yes, if your trigger wires were reversed you would see 10 degrees of timing change but it would be steady.
Joe Buchanan SS/BX 3117 Last edited by buzzinhalfdozen; 09-08-2014 at 03:11 PM. |
#12 | |
Liked 13 Times in 11 Posts
This grief is a pain in the arse to trouble shoot. What filter and where is it? I'll try another wire later today |
#13 | |
#14 |
Liked 275 Times in 76 Posts
http://www.msdignition.com/Products/...,_26_Kufd.aspx
I would not go buying this unless you have exhausted everything else.
#15 | |
Anyway , thanks. I look at everything else first |
#16 |
Yeah I've put at least 50 or more MSD ignition systems on cars, from basic 6al to the digital stuff and have never installed one of their filters. Though it's possible it may cure yours I'd bet if anything it may mask the real problem. I'll assume you've went back thru and verified all connections and lay out of wiring is correct? Main power and ground go to batt. positive and negative? Believe it or not if those 2 things aren't true you can have some real issues. I've seen some pretty cobbled up installs of MSD systems and for the most part they all worked, however as with most things when they add more "stuff" (digital systems) the proper installation is more critical. Make sure you've got all the wires ran correctly, not just the way they were with your old system. One last thought...where is your controller mounted at least in relation to the coil and high voltage lines?
Joe Buchanan SS/BX 3117 |
#17 |
Liked 320 Times in 102 Posts
I know that you are not going to believe this.......But I made a mistake ONCE
I had the pickup polarity reversed and the timing mark bounced around like crazy. This was on an MSD-7A and crank trigger.... With the shielded leads they did a color swap and that caused my problem.... I reversed the leads and the problem went away.... It seems like a pretty easy test to do and it might solve your problem.. Bob
#18 | |
#19 |
OK , Lets end this .......thanks for all your input BTW.
I had a friend of mine stop by with his plastic ( newer than my metal body ) Actron light......and it read the timing! Actually surprised the crap outta me........anyway , my lights that normally work are suddenly quirky..........all those lights ( 3 ) are years old with the exception of my Flaming River light.......but his worked. Anyway , I'm buying another light ( same as his ) now I'll have 5 lights LOL |
#20 |
Glad you found your issue, my first thing when someone local has this issue is to use my timing lite to see if that's the problem, then go from there. Guess one can never be sure. BTW you actually will only have 1 lite that works on your race car!
