Old 08-21-2014, 12:24 AM   #7
jmarkaudio
Default Re: Throttle Stop Carb Selection
So since you are running a spacer under the carb you have an inline throttle stop? The QF carb should be fastest on your engine. Why not go to a test session and run a couple of them?
jmarkaudio is offline   Reply With Quote
