Old 06-21-2014, 05:23 PM   #1
nomad
Liked 7 Times in 4 Posts
Default Re: TS Cylinder intermittently closing slowly????
I've noticed my is doing the exact same thing. Thank goodness for data recorders. It's easy to see and the time where the stop closes slowly is always in the .16-.17 second range.
It's a D'bear TS 30 and gets a lot of use. I also use it for an SLE when bracket racing. I called D'bear and even the tech was knowledgeable he was unable to assist me.
Don, do you have a part number on that cylinder? Is it a Grainger part?
nomad is offline   Reply With Quote
Old 06-22-2014, 10:51 AM   #2
rob7181
My problem ended up being a bad regulator!
rob7181 is offline   Reply With Quote
Old 06-22-2014, 10:54 AM   #3
Don Higgins
I don't have one available right now. I just ordered the replacement from #1 Stop.
Don Higgins - Super Comp #360H
Don Higgins is offline   Reply With Quote
Old 06-22-2014, 02:14 PM   #4
nomad
Thanks, Don. Changing every so often is probably a good idea. I don't imagine they cost much.
I'll get mine apart and measure all the specifics and post them here.
