#20 | |
Liked 49 Times in 15 Posts
It gets even more interesting if you convert apples to apples. Since a 2BL is flowed at 3 inches vacuum and a 4BL is flowed at 1.5 inches of vacuum, you need to multiply the 2BL CFM by roughly .707 to get a value you can directly compare to a 4BL carb. So 287 X .707 = 203 CFM Using a quick online CFM calculator: 267 CID, 5500 RPM, 80% VE........ would need about 350 CFM minimum
Dean Feiock -- Stock 5002 |
