#5 | |
Liked 1,583 Times in 582 Posts
FRAME Frame or subfloor must be stock for body used. Subframes on unibody cars may be joined under car. FIREWALL Alterations prohibited. Firewall coverings prohibited. FLOOR Removable floor section for transmission/shifter installation permitted; restricted to 6 square feet (2 x 3 feet, 1 x 6 feet, etc.) of steel material identical to area removed. Stock floor may be sectioned where rear framerails have been narrowed. Area between framerails must be stock floor, in original location. Area between new rear framerails (from four-link crossmember rearward only) and body may be replaced with material equal to or heavier than original; must be in original location. All other floor material must be stock and in original location. Theses excerpts are straight from the rule book... |
