Liked 16 Times in 5 Posts
Doug, the Turbo Action valve body w/1-2 shift uses the governor system,whereas the ATI eliminates the band and the governor. Of course with the Turbo Action, the shift points are determined by changing the weights and springs in the governor. Your choice!!
Liked 84 Times in 21 Posts
Thanks Bob^3240. But is one faster than the other because of band drag?
Neither one uses the band. With a real low first gear, the auto 1-2 shift will make the car more consistent because the shift lite comes up so quickly! You don't need the band for drag racing. Bob Michael
Liked 166 Times in 46 Posts
I have built many Turbo 350's using the Turbo Action Auto 1-2 shift valve body, and IMO it is a very good piece of equipment.
Thank you all for responses.
