Go Back   CLASS RACER FORUM > Class Racer Forums > Factory Stock and Super Stock
Old 01-13-2014, 09:57 AM   #11
GUMP
Liked 1,744 Times in 423 Posts
Default Re: 2014 COPO Engines
Originally Posted by Mike Keener View Post
Kudos to 6 races instead of 3 Jeff. I love to see heads up racing but I knew this would happen with the 450 deal as soon as GM announced it. Obviously Mopar and Ford will follow suit and everything will be right back where it started.
Looks to me like everyone should have been happy with things the way they were and kept it to the 427 deal so everyone with a fortune invested already didn't have to start over with their engine programs in order to remain competitive.
Not to mention you will obviously have to have a 2014 car in order to run the new engines. Oh well too late now. Looks like the 450 train has left the station.
MK
It seems to me that the problem with the 427 is the weight break being at 450 for the shootouts.
For the regular classes, I think that Chevrolet has done a very good job of looking after the older N/A combinations.
Old 01-13-2014, 11:13 AM   #12
Bob Shupe
Bob Shupe's Avatar
Mr Adams is this going to be a plan for the BODY IN WHITE???
Bob Shupe is offline   Reply With Quote
Old 01-13-2014, 02:05 PM   #13
Dyno
Dyno's Avatar
Liked 607 Times in 178 Posts
the 450 is a .100 stroked 427, same bore od 4.125, with mechanical roller lifters and they must have changed the head because there is a different part number. Fun to own one. Dyno
Old 01-13-2014, 03:04 PM   #14
Mike Keener
Liked 25 Times in 13 Posts
Different piston config, more cam, more intake runner volume, bigger valves, more rocker ratio, etc. About the only thing you can use from a 427 are the rods, the manifold and throttle body, and the block.
MK
Mike Keener
A/S B/S
C/SM
Mike Keener is offline   Reply With Quote
Old 01-13-2014, 03:56 PM   #15
GUMP
About the only thing you can use from a 427 are the rods, and throttle body.
I think it would end up more like this.
Old 01-13-2014, 05:04 PM   #16
Mike Keener
Nope...same exact block with a 4.200 arm, and the manifold and throttle body are exactly the same as the 12 and 13 427's.
MK
Mike Keener
A/S B/S
C/SM
Old 01-13-2014, 07:44 PM   #17
GUMP
Understood, but I am sure that we will see this combination "evolve" a little before it sees an NHRA event.
Old 01-14-2014, 08:22 PM   #18
Jeff Teuton
Liked 326 Times in 50 Posts
Started the process today to get that .200
Jeff Teuton 4022 STK
Old 01-15-2014, 12:53 PM   #19
Brett C
Liked 877 Times in 196 Posts
On your COPO????
Brett Candies
4192 Stock/SS
God Bless America
Old 01-15-2014, 10:47 PM   #20
Jeff Teuton
On my Mopo. 2.30 intake 1.70 ex. big new intake 699 cam 16 to one compression
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
