Old 01-13-2014, 07:17 AM   #19
rodrocket
Default Re: Mega 450 Wiring Help
do you guys run a switch in the main power supply wire running to the Mega 450 box or wire it to the main power supply & let the Master Disconnect switch shut the box down
is there any advantage to run a seperate switch to shut the Delay Box down with the engine running ect to re-set the box
regards
Rod
rodrocket is offline   Reply With Quote
