Old 11-23-2013, 02:13 PM   #5
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
Thumbs up Re: Q-jet ?
we used it over it vacuum tested fine and was working when removed.
Thanks for the help.
Originally Posted by Alan Roehrich View Post
I would not use a needle that does not have spring stabilization in a boat, if the original had one in it. The rough ride you get in a boat on the water bounces the float around a lot, and you'll have problems with keeping a stable fuel level in the float bowl. A Q-Jet is fairly sensitive to fuel level for metering purposes.
Glen DeMenge
1969 Camaro Stock Eliminator
MEXJOE is offline   Reply With Quote
