Old 10-21-2013, 03:10 PM   #1
FED 387
Liked 332 Times in 180 Posts
Default Re: Best Place to Buy GM EATON 800 8.5" Posi
Dan--- why don't u just buy the 800# preload kit available under Eaton part number 29591-OOS this is the 800 pond pre load kit springs & plates available from Summit for $89.97 ---by th way Summit shows a picture of it ----Has to be cheaper than buying a whole posi unit for about $450 ---Good luck FED 387
Old 10-21-2013, 05:17 PM   #2
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Originally Posted by FED 387 View Post
Dan--- why don't u just buy the 800# preload kit available under Eaton part number 29591-OOS this is the 800 pond pre load kit springs & plates available from Summit for $89.97 ---by the way Summit shows a picture of it ----Has to be cheaper than buying a whole posi unit for about $450 ---Good luck FED 387
Thanks FED..
Yeah, seriously thought about that..!
A new Posi would be twice the cost to rebuild but simpler quicker to install.
PN for the Springs is $90, Carbon Disks another $119.00.
It is still good for the street and drag racing.
Have the option keeping it for a street project, the 94 Caprice SSuperwagon being set up for towing or sell to a B-Body racer.
Should be a wash after selling it.
In past have rebuilt a 12bolt Moroso Posi with new Springs from Al's Differentials.
Built a clamp tool out of 2x4 and to force them inside the cavity with a hammer.
Eaton has three types of clutch service kits.
OE, 18 disc (standard), 24 disc (high performance), the modern day, high tech 14 disc carbon fiber design.
Last night studied all about their characteristics.
Still need advice on which of the last 2 to buy.
Dan
Old 10-21-2013, 09:52 PM   #3
Tim Kish
Liked 11 Times in 4 Posts
Call the Eaton tech line: 800-328-3250 Either Barney or Brent should be able to steer you in the right direction.
Tim Kish
3032 SS/GS
Tim Kish is offline   Reply With Quote
Old 10-21-2013, 10:57 PM   #4
Dan Fahey
Dan Fahey's Avatar
That is great information..thanks.
D
Old 10-22-2013, 11:45 AM   #5
Dan Fahey
Dan Fahey's Avatar
FYI..that Number is for some Florida Vacation spam..
Here is his correct information
Brent Bussell -Customer Support
Technical Specialist
Phone# (248)226-6762
Fax# (248)226-6740
Old 10-22-2013, 02:16 PM   #6
FED 387
toll free # is 800-328-3850 x 6762-otherwise the other # is his direct line phone #-FED 387
Old 10-22-2013, 04:50 PM   #7
Dan Fahey
Dan Fahey's Avatar
Brent suggested for Drag Racing using the 24 Disk Steels.
For the Street the 18 Disk Steels..
Dan
Old 10-22-2013, 05:09 PM   #8
peteprostock
Dan .. my Eaton catalog shows 1988 -96 10 bolt clip 8.5 / 8.6 with 30 spline 2.73 gear & up # 19559-010
peteprostock is offline   Reply With Quote
Old 10-22-2013, 05:19 PM   #9
Tim Kish
Fax# (248)226-6740
My apologies. I got the number from the product engineer in the cube next to them. He must have fat fingered the number.
Tim Kish
3032 SS/GS
Old 10-22-2013, 05:59 PM   #10
Dan Fahey
Dan Fahey's Avatar
No Problem..
I have finger dyslexia too
Contacted Brent and he gave me a wealth of information.
Dan
