Old 09-27-2013, 08:32 PM   #6
jim hensley
Default Re: Inline race jug filter
Originally Posted by Doug Domm View Post
I hear you Mike. I've been using the same thing in the past and am looking to ditch the funnel thing altogether. I'd like to pour from jug to cell with the hose on jug cap but would like some kinda inline filter too. Just trying to get some ideas from what others may have used. Doug
In the fuel system, aeromotive recommends you run a 100 micron filter on the inlet side of the pump, and a 40 micron on the outlet. Magnafuel recommends a 74 micron on the inlet and 25 micron on the outlet. I run the magnafuel 25 on the outlet side only, I use stainless steel mesh, stay away from paper elements. Some question the fact that if the prefilter becomes plugged, the fuel pump has to pull through a restriction which causes cavitation with resulting fuel pump damage and other problems. I do not run the prefilter because, instead like others I use a funnel with a screen in the bottom when filling the jugs from the drum and filling the fuel cell. I realize the benefit of not using a funnel though, the problem with a funnel, it's a pain not to be able to see your fuel level while you are pouring.
As far as a inline filter on your actual jug hose goes, I don't know of anyone making one like that, but it would be nice. You might could rig up one if you could put a AN10 fitting on the jug hose and then attach one of these inline filters to it.
jim hensley is offline   Reply With Quote
