Old 09-05-2013, 07:56 PM   #81
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
Default Re: Crank Trigger
Originally Posted by Todd Hoven View Post
I wasn't going to join this but I figured I would stick in my 2 cents. I had a problem with with my engine in the begining of my race season with a high speed miss above 6500. I chased the normal things, but wound up with a cam profile issue that caused destabilization in the valvetrain above the rpm stated above rpm. After a cam change my problem was solved. One of the conditions that was resolved was the timing jumping around while trying to set it. My issue is a small base circle cast cam core that was flexing with the aggressive lobe. The new cam had a different lobe and a slightly bigger base circle and cam core. I figure my cam was flexing and this was the reason for the timing variation.
I can see benifets to a crank trigger, when you are running very aggressive roller cams with alot of spring pressure causing cam flex in certain circumstances, and timing variation. With a crank trigger you eleminate a few parts that can cause an issue, nothing is more accurate than taking a signal off of the crankshaft. If you have a big enough cam core, and the right lobe design for what your trying to do, I'm sure a distributor will work well. I'm not really sure you will any ET in one over a good distributor. But I'm sure it won't slow you down. Your mileage may varry. Good luck.
now, if your distributor was at the FRONT of the engine, you wouldn't have had this problem,correct?
Old 09-05-2013, 08:33 PM   #82
Chad Rhodes
Originally Posted by buzzinhalfdozen View Post
Oh I think 1 retard in that car is enough.
Bwahahahaha
Chad Rhodes 2113 I/SA
Old 09-05-2013, 09:28 PM   #83
Todd Hoven
Guest
Posts: n/a
I'm sure I wouldnt.
Old 09-05-2013, 09:45 PM   #84
R Lowry
Liked 2 Times in 2 Posts
1320 racer, why don't you just shut up!!!
R Lowry is offline   Reply With Quote
Old 09-06-2013, 07:54 AM   #85
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Todd, I'm pretty sure my cam with over .800 lift and 30 degree intensity and spring pressure falls under what you might call..."very aggressive roller cams with alot of spring pressure" with . Now IF my cam is flexing(standard BBC core btw) and my timing varying, it's doing it exactly the same every pass on any given day, 36 weekends a seeaon, 250+ passes a season because it ain't showing on the time slip with runs that typically vary thousanths from pass to pass.
BTW, I also run 3/8" .080 wall, 1 piece pushrods and ain't ever broke a pushrod in any of my race engines EVER!
Old 09-06-2013, 08:30 AM   #86
Jim Kaekel
Liked 535 Times in 110 Posts
BTW, I also run 3/8" .080 wall, 1 piece pushrods and ain't ever broke a pushrod in any of my race engines EVER![/QUOTE]
There's a statement that shows your complete ignorance. Pushrods flex a helluva lot before they break. I would think that a 7/16" x .120" wall pushrod in your car would pick up some HP and I'm surely not "Grumpy" Jenkins.
Jim Kaekel 3836 STK
Old 09-06-2013, 08:31 AM   #87
Pedigo Perf
Pedigo Perf's Avatar
Liked 30 Times in 17 Posts
Why would you need the best of anything in your cushy little bracket car. You can get by with a lot of slop if you don't need to outrun a guy who is pushing the limits. Clearly this game is NOT for you.
Pedigo Perf is online now   Reply With Quote
Old 09-06-2013, 08:37 AM   #88
1320racer
1320racer's Avatar
coming from the guy that thinks timing changes with oil viscosity and oil temp who also can't apply the proper torque on a stud or bolt to keep a distributor clamp from loosening up.
There's a statement that shows your complete ignorance. Pushrods flex a helluva lot before they break. I would think that a 7/16" x .120" wall pushrod in your car would pick up some HP and I'm surely not "Grumpy" Jenkins.[/QUOTE]
and you would be wrong! Grumpy raced Pro Stock a long, long time ago and built high RPM engines for comp and pro stock which neither you are I are doing!
Further, these same pushrods are in 1000s of engines built by the biggest names in sportsman engine builders, run in the super catagories as well brackets.
Old 09-06-2013, 08:39 AM   #89
Joe Toller
Liked 9 Times in 9 Posts
It's obvious to me that 1320 is just *very* insecure. He gets off on this because he has little else to do. Like the youngsters say, "don't feed the trolls."
Why else would he be spouting off on a class forum, if he's not a class racer?
Old 09-06-2013, 08:40 AM   #90
buzzinhalfdozen
Liked 11 Times in 8 Posts
Jim, dead on with a 0, a 3/8 pushrod unless possibly it's .120 wall with any real cam profile or spring pressure bends like crazy....seen it personally, not merely speculation. Would see witness marks on the head of rubbing with an observed static pushrod to head clearence of at least 3/16 of an inch please don't try to help this person!
Joe Buchanan SS/BX 3117
