Liked 759 Times in 379 Posts
I've made more passes on radial slicks than most running stock eliminator. A tenth is the number you usually hear on small block cars but you won't see that on big block cars.
Liked 13 Times in 9 Posts
You can find the M/T tire guide info here: http://www.mickeythompsontires.com/s...m=ETDragRadial
They have two different 30x9 radials, one taller, one wider. I always ran the 3066R (shorter 93", but wider, true 9" tire). 110 passes like clockwork, prints tickets, and was .12-.13 faster than the bias plys. Won a Bracket Finals, World Footbrake Challenge, and a Stock World Championship on these tires. Only ran the 29.5x9's through one set. Also a good tire, but the 3066R's just fit my gearing better, and liked the extra tread width insurance.
My car does consistent 1.48 60fts with an overcammed bracket
engine. My tires don't rub, down track, just around corners, forward or backward. I thought I'd give the 29.5 Mickey's a try, because they would give me a gear between. 4.56 and 4.88...and figured they would hook just fine,as long a track was good. I bought bias, last year, before my front suspension was redone, with global west stuff. I figured radials wouldn't work too well, with factory stuff. My car seems to work pretty good,,and I think it'll work even better, with more converter and gear.
1968 Bird/TRW 455/Home ported 13's, '70 Qjet,Holley Street Dominator manifold, Comp Solid FT, 10.817/122.30/1.440 Workin' on E/SA combo ![]() |
#4 | |
Another was to Santuff shocks.
Ed Wright 4156 SS/JA |
Liked 536 Times in 110 Posts
I've got a big block Stocker and had two sets of slicks, one bias ply and the other radial. I picked up .10-.12 every time I backed-to-back them, and that was nearly 20 years ago.
Jim Kaekel 3836 STK |
radials slicks back in '93, I don't think so! Maybe you were a tenth quicker with a slow "big block" olds back when it was running in the 12's but NOT with a real big block launching a nearly 2 ton ride...
Don't be so quick to reply. You can race a long time and not know everything. Why you would doubt Jim Kaekel is a mystery to anyone that has seen him race for decades in division 3 with a stocker. I get it; your old bracket car was cool! I had a poster of it. It does not make Jim wrong.
James Schaechter 3163 STK |
#8 | |
Liked 11 Times in 8 Posts
Comparing your bracket car to an actual STOCKER is meaningless...... I've never used the "small tire" however big or small block on a big tire it's .08 to .12 in almost every case. This may or may not be due to the physical size of the tire I don't know. Oh and James he does indeed know everything just ask him.
Joe Buchanan SS/BX 3117 |
#10 | |
Ditto the "10.5" shoot out" cars. Apples & oranges. With my little 3240 lb, 350" SS car, radials were usually almost two 10ths quicker before I had it back-halved. 10.5" tires back then. have not tried bigger bias tires yet. Can't spin these suckers.
