Old 04-23-2013, 11:22 AM   #1
Brandon Peterson
Default Q Jet spacers, Q Jet upgrades
I was wondering what Quadrajet spacer everyone uses or has tested to be the better deal, i saw alot of Wilson spacers at Charlotte but i was told the Moroso was the better spacer, Also how do you know if you have a good Quadrajet carb, i have 2 one i bought off here for 600 dollars was told it was a Danny Ashely i belive, and the other came on a turn key motor and i was told it was a Boburka which is on the car now, how do i know if it is a good carb or i need more work on them, i guy looked at my spare carb which is 4 hundreths slower than the Boburka, and told me it was pretty much a stock Qudrajet.
Brandon Peterson is offline   Reply With Quote
Old 04-23-2013, 12:05 PM   #2
Kevin Panzino
Kevin Panzino's Avatar
Liked 747 Times in 136 Posts
Default Re: Q Jet spacers, Q Jet upgrades
assuming you are talking about a 2" open spacer, there is little to no differnence amongst brands. The 4 hole pnenolic insulating spacers do vary I have heard ( no personal experience).
As for the carb, if your guy does not specifically know Q-jets he may think its stock when its not.. But there are lots of little things inside you cant see. A 'stock' carb would be an enternity slower than a Boburka. If you have another carb thats within .04 of a Boburka, its a good carb.
Old 04-23-2013, 12:13 PM   #3
Brandon Peterson
Yes a standard 2 inch spacer is what is on my car.. Nothing special... I felt like I had 2 good carbs but nothing was told to me as why my spare was pretty much a stock core... To me it looks better than a stock carb... Thanks for the info
Old 04-23-2013, 12:20 PM   #4
Dick Butler
Liked 32 Times in 19 Posts
Brandon, I think some combine a 1 inch 4 hole and an open 1 inch. I have seen the taper bore 4 hole and have no knowledge of its affect. Have you tried the angled spacer yet?
Consider Val Hedworth for the carb. We had good luck with them. I have two Boburka 85, 305 type Q jets for sale.
Old 04-23-2013, 12:51 PM   #5
Mike Pearson
Mike Pearson's Avatar
Liked 1,916 Times in 574 Posts
There is no better q jet builder than Jim Boburka. If it was built by him it will have JBR stamped on it near the carb number.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 04-23-2013, 01:47 PM   #6
Brandon Peterson
My Carb has JBR stamped on it a few places..
Dick, my old intake has a angle on it but i havent tried that intake with this new combo, and i have not tried a angle spacer, my spacer on the car now is a 2 inch Mr. gasket, and a regular carb gasket, my other intake has a Moroso on it.... i have not tried the 4 hole but wondering what it would make in HP
Old 04-24-2013, 09:35 AM   #7
Monte Howard
Monte Howard's Avatar
Liked 66 Times in 22 Posts
Brandon, the only way to tell if one Q-jet is better than the other is to test them at the track. You can have the same carb builder build you 4 carbs and they are all goi g to vary within probably .08. It's all in finding a good core and the only way to know if its a good core is run it down the track.
Monte Howard 3209 STK, 3208 SS
Monte Howard is offline   Reply With Quote
Old 04-25-2013, 02:54 PM   #8
Brandon Peterson
I have ran both down the track plenty of times... I have just been told that they both need work and are pretty much stock cores... I see plenty of things that have been done to both carbs I am starting to wonder what else could be done if I see all these upgrades done to it but its still called pretty much stock... I put a Holley 750 on it last year at a bracket race off my stocker and it ran the same et as my quadrajet ran that day
