Liked 13 Times in 11 Posts
The Nova this weekend. First pass was a 9.53 , second a 9.51
Nash 5 speed Last edited by joespanova; 04-19-2013 at 06:21 AM. |
NICE!!!!!
I'm a FORD guy, but that car is BAD *****... That a NASH 5-speed?? I just got one for my car..
DESTROKED 300 (272ci) |
Liked 306 Times in 103 Posts
Like the car.
Was I seeing things or was car rolling in beams both passes? Where are you located I noticed UMTR sticker Mike Taylor 3601 |
#5 | |
Ga. Video is a great aide , isnt it. The first thing I notice is the bump valving is too stiff , rebound on driver side also. I'll change those and see what happens. Last edited by joespanova; 04-19-2013 at 08:47 AM. |
Is that NASH pro shift or face plate?? Sound like it shifts real good...
Mine has 1-2 pro shift / 3-4-5 face plate....
#7 | |
Face plating was the best thing I did. |
Your making way more horsepower then me!!! I make about 400-415hp not to bad for a inline 6...
What's your car weight and what first gear ratio is in the trans???
#9 | |
Engine is 355 , stock block , 23 degree head ( std. port ) Power is probably around 635 - 640 |
Mine is 2800 w/dr, the trans came with 3:25, but I have a 3:05 for it..
The engine is a destroked 300 (272ci) inline 6 Ford (400-415hp) depending carburetor set-up... My best ET 10.96@120 multi carburetors and 11.14@118 single 4 barrel...
