It is rather confusing a first, Hang in there.
2009 V/SA Record Holder |
my car is a 1970 plymouth duster with a 318 2 barrel. i am hoping to run N/SA but was wondering on my weight
Liked 10 Times in 6 Posts
Duster 318, N/SA 2850, O/SA 2945, P/SA 3130 with driver. 318 at 185 hp. Tom
Tom Moock 5704 STK |
I've been racing a Duster for years, and I can't see how you could get one with a 318 in it under 3000 lbs. with driver in legal stocker trim. Duster 318 I would shoot for O, but if you don't remove everything possible and put light weight brakes etc, you'll be closer to P weight.
If the car has frame connectors,a roll bar and 8 3/4 rear it will most likely be between 3000- 3100 lbs without the driver. Good luck, George |
i havent had the car weighed yet im hoping its closer to N/SA but i dont have a problem running O either. it has a roll bar in it with a bar underneath to. tom i thought the hp was 230?
Liked 15 Times in 7 Posts
Duster 318....I have a72 duster and i raced all last year in e/sa min wt 3100 and i carry way more in the drivers seat than the 170 std....haha good luck to you bryan stk511
