I am looking to buy Shumann low volume oil pump for my chevy ss engine .Witk lack of experience with that kind of pump , what do you recommand?
Any input please . Thank | |
I use a Larry Stewart low volume pump in my small block SS engine. Works perfectly!
Larry is a great guy. Larry Stewart Perf 601-259-1597.
Ed Wright 4156 SS/JA |
Liked 99 Times in 49 Posts
I have one of larrys and a the other one biggest diff is the by pass. Jim
Liked 1,538 Times in 575 Posts
I have seen the Schumman oil pump used in many different brands and they perform very well including a Procharged LS-1 making over 1K HP.
What about the bypass, Jim?
Sounds good. I would sure think about that one if I wasn't so happy with the one I have.
Not to be a smart azz, but he needs to proof read his material. Or, fix his space bar/key.
#8 | |
I had a talk with Mr. Schumann; he is 70+ years old. Nevertheless, the man spent about 40 minutes sharing about oil pump design, Tribology fluid mechanics and lubrication. He even sent me pictures and sketches regarding using his oil pump with a wet sump pan and using an external Peterson oil pressure regulator to control flow and pressure, short of acting like a dry sump system. |
Liked 269 Times in 99 Posts
The guys at Schuman are really great. Had a good conversation with them at IMIS in December.
Have a Stewart Pump for Small Block Chevy. Make an offer!
