Please just want to know, what pump will work the best and not rob H/P
Thank You ![]() |
Call Larry Stewart Sr at 601-259-1597.
Ed Wright 4156 SS/JA |
Liked 3 Times in 1 Post
Liked 13 Times in 4 Posts
Joe Schaechter 3168 STK |
Liked 1,758 Times in 398 Posts
Yep, that Schumann pump is a nice piece. If the low volume version makes you nervous, they have a standard volume version. I've been really happy with the Schumann pumps, they're made out of the same material as heavy rear end housings are made out of, plus they have billet gears, not powdered metal, and they have a screened bypass that dumps excess pressure and volume to the pan, instead of recirculating it to the inlet, where it heats the oil and aerates it.
Alan Roehrich 212A G/S |
Liked 269 Times in 99 Posts
#7 | |
Thanks.
Jeff Lee 7494 D/S '70 AMX |
http://www.schumannsdynamicperformance.com/
The owner's name is Vergne Schumann. I don't see a listing for anything AMC, but he makes stuff for Oldsmobile, so the possibility does exist. Vergne is real sharp, but he's kind of blunt.
Thanks, l will call him next week.
Blunt and I get along real good...
resurrecting an old thread here, but didn't think it necessarily should start anew.
Looking into a low volume oil pump for a SBF for stock eliminator. Schumann at one time had one listed, but i do not see this on their website anymore. Jegs has a Low vol pump w/ cut down gears (.660" vs .875" stock) and a 40 psi pressure relief spring for ~$200. I don't see any other options on the interweb and wanted to see if anyone had any experience w/ the jegs piece, or thoughts on a 25% reduction in gear thickness and 40 psi relief. I'm inclined to give it a try but thought i'd ask first. Thanks in advance! Alex
Alex Cummings Newb |
