Old 12-29-2012, 09:53 PM   #1
Liked 5,138 Times in 1,961 Posts
Default Re: question for the smart guys
I'm not sure I qualify to respond here , but here goes:
The 87 THM GT will make T/SA .
@ 150 HP, I think it's a bit high...Ask Jim Wahl about that combo. It's 155 in the Cimarron, FWD but you get a .430 lift cam.
The TH125 is essentially a mini T200, so all the low drag tricks would apply.
You are limited with the final drive , but a really short drag radial would work fine ,as I can't see how traction would be an issue.
Cams are available..390/ 410 lift is what a lot of the 350 Chevies use.
You'll have to fab the headers. You used to be able to get S10 kit pieces.
I'd build a 7 " converter to get the rpm's up to make up for the gear ratio.
I think it would run the NHRA index without too much trouble
Old 12-29-2012, 10:31 PM   #2
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
wasn't 88 last year. I worked across the shop from them on Isuzu's.
I thought they were from 84, the 84C15 recall cars, to 88GT's where they finally got them right but public gave up on them. This is all from memory tho....
chris ok is offline   Reply With Quote
Old 12-29-2012, 10:51 PM   #3
skills
Liked 8 Times in 1 Post
Yes you are right 84-88 always wanted one. Just thought that would be an interesting challenge. Also they are rwd.
skills is offline   Reply With Quote
Old 12-29-2012, 10:57 PM   #4
84 and 88 are not in the book.
Old 12-30-2012, 12:30 AM   #5
RonTheAnnouncer
RonTheAnnouncer's Avatar
Saw this one day at dragway 42 running mid 17s...
Ron Huntley, Jr.
announcer and Half ed racer
"Those who can, do. Those who can't, criticize."
RonTheAnnouncer is offline   Reply With Quote
Old 12-30-2012, 12:35 AM   #6
RonTheAnnouncer
...and this at Norwalk a few years ago at the Halloween Classic.
Ron Huntley, Jr.
Old 12-30-2012, 09:35 AM   #7
Billy Nees
The car I was playing with was an 85 2.5/120/113 car. It is a natural V/SA that can make W. The car has a "stupid computer" in it that you can make do what you want it to. It has a pretty big throttlebody and the heads and intake look good. Biggest problem would be the transaxle. The best final drive that you can get from the factory is a 3.73. I've heard that there's someone in upstate N.Y. that might make yoy a 4.10. Yac can make you a converter and even do the trans for you. 4 cyl car has got enough room that you can make your own headers. Find the shortest slicks that you can (or even drag radials?) and it would probably do much better than index. It would hook in a carwash.
I think in hindsight that it could be a fun little car and would probably run well. I probably didn't give it much of a chance as I really didn't like the "disconected" feel that I got while driving it.
Billy Nees 1188 STK, SS
