Liked 284 Times in 87 Posts
Ed... That is the standard base from an OEM open element HP air filter assembly. It came on Quadrajet and Holley performance applications 1966-69. Someone has done a clean job of making it work with the 4GC, adapter ring and fuel inlet tube. You most likely will have to make your own from the picture. If you need a base, try Corvette Central or Classic Industries. I hope this helps.
