Old 09-11-2012, 03:47 PM   #8
FED 387
Liked 330 Times in 178 Posts
Default Re: Quadrajet Gasket and tuning
FIRST get rid of the BG pump--second buy an Aeromotive pump like a 11203 uses less AMPs, Magna Fuel or a Weldon both great pumps too-- stay away from the Holleys too---check ALL your hose sizes make sure they are adequate for your set up place fuel pressure gauge so you can monitor whats going on during the run--then if problem persists call D.A.
